PCTV tripleStick 292e
I have now purchased a PCTV 292e in the hope that it will be supported soon ;)
I have a VU+ Solo2, running BH 2.1.3.
The 292e does not show in my VU+.
Dmesg gives the following:
em28xx: New device PCTV PCTV 292e @ 480 Mbps (2013:025f, interface 0, class 0)
em28xx: DVB interface 0 found: isoc
em28xx: chip ID is em28178
em28178 #0: EEPROM ID = 26 00 01 00, EEPROM hash = 0xa911fb04
em28178 #0: EEPROM info:
em28178 #0: microcode start address = 0x0004, boot configuration = 0x01
em28178 #0: AC97 audio (5 sample rates)
em28178 #0: 500mA max power
em28178 #0: Table at offset 0x27, strings=0x146a, 0x1888, 0x0a7e
em28178 #0: Identified as PCTV tripleStick (292e) (card=94)
em28178 #0: dvb set to isoc mode.
usbcore: registered new interface driver em28xx
WARNING: You are using an experimental version of the media stack.
As the driver is backported to an older kernel, it doesn't offer
enough quality for its usage in production.
Use it with care.
Latest git patches (needed if you report a bug to linux-media@vger.kernel.org):
aaba32e6535993e4724861f5ae5c912be4c9628a fix rc_core_debug unknown symbol
031cbbf30fa25b1005f7a76a4a4af38a29da2156 cleanup rc_core
ed77bf06578c345e91460a80e6c301ac56f1a68e fix rc_core
em28178 #0: Binding DVB extension
i2c i2c-5: Added multiplexed i2c bus 6
si2168 5-0064: Silicon Labs Si2168 successfully attached
em28xx: Registered (Em28xx dvb Extension) extension
Use it with care.
I've bought a PCTV 292e during this week from Amazon.
I'll get it saturday from my parent's home and I'll test it directly.
290e is not available anymore. Thats why we need support for the 292e. It is one of the few (if not the only) sticks that support dvb-t2.
I only have access to dvb-t2 channels in my area, so all the dvb-t sticks cant be used here :(
