Project-Valerie
You can install r517_bh.tgz and Project Valerie will check if there are any updates available online every time you start it. It will then download and install the updated version if you wish. The latest version is r750.
Hello.
Can I Exclude Genres from Movie Filter.
- Lets say I want to view Animation or Drama Movie.
With current sort filter only one Genres is displayed at the time.
If I select Drama all movies (Animation or Not) is displayed.
If I want Drama only Movie not Animation I can't do it.
If I want Animation Genre Drama Movies I can't do it.
By pressing sort filter Drama, All movies including Animation is Displayed.
An Genres Exclusion will be most useful. :)
Regards
HellI and congratulations on the project,
I manually install ipk of PV, now how do I unistall this plugin?
Thanks,
Tiago
Thanks,
Tiago
Go to:
usr/lib/enigma2/python/Plugins/Extensions
Then delete the plugin paste (in this case Project-Valerie) and restart. That's it.
tried this plug in a few times but it keeps crashing my Ultimo with image 1.7.2
it asks would i like p.v. to start at start up and would i like p.v. to look for updates and it doesn't matter what way i answer it keeps rebooting after that.
hi guys,
did install PV but had to uninstall just after.
setting up to StartUp automaticly, UNO with BH 1.7.4 did not start and went after 1 or 2 seconds to Green Screen(CrashScreen).
Tried to get into MENU by pressing fast MENU, did match, then configured to Don't start automaticly and did software Update to last rev. Tried again but still crash.
so I decid to uninstall.
regards
hi guys,
regards
It is long long time when i tried it for the last time.
I'll look for some time to try it and let you know.
