Ralink 3070/3370/5370/5372 driver for new Vu+ kernel
First page of this thread - post n. 3
Hi!,
Thanks for your reply, I am new to this after installing ikp file where to configure this
#ifdef RT5370
{USB_DEVICE(0x148F,0x5370)}, /* Ralink 5370 */
{USB_DEVICE(0x148F,0x5372)}, /* Ralink 5370 */
#endif // RT5370 //
also I need to know from post 3 which file is for 5370 i found only 3070 files only.
Hi!,
#ifdef RT5370
#endif // RT5370 //
You don't need to configure anything.
In the post #2 of this discussion I've reported (REPORTED) the USB IDs included in the drivers posted (one file for every box supported) on the post n. #3
Install the file for your box and reboot it.
Hi Angelofsky, not to give any pressure but judo to Know if I'll have a working driver or if it is better to buy another dongle. Thanks for your job.
If you can, change dongle.
My ordinary work takes me a lot of time ... Hope to have some (and more) spare time to spend in SAT scene starting from Decembter 2014.
Hi,
I´m trying to install the driver on solo2 bh 2.1.4 image but it report me the followin error: "Package rt3070 md5sum mismatch. Either the opkg or the package index are corrupt. Try 'opkg update'."
It´s not compatible with that version?
Thanks for help
hello
my Wifi Dongle
USB\VID_148F&PID_7601&REV_0000
Ralink Technology, Corp.
i am using VU+SOLO
please help
