Ralink 3070/3370/5370/5372 driver for new Vu+ kernel
In this thread there is the IPK for all Vu+ boxes that contains Ralink driver chipset.
Installation instructions:
a) put the IPK into a USB pendrive and connect it to your box. You will have the possibility to install IPK directly.
b) put the IPK into /tmp folder of your box and use the "Manual install IPK package" from BH Green Panel -> Yellow Button.
Supported devices will be avaiable on the second post of this thread.
Drivers avaiable! Make post here with feedback, please!
thanks
thank you
Hi,
I got a D-Link DWA-127 and its not working
vu+ solo2
Black Hole Vu+ Solo2 2.1.6.1 Fast IPTV
rt3070_2-5-0-3-r4-bh0_vusolo2-ipk
Chipset: Ralink RT3070
root@vusolo2:/# lsusb
Bus 002 Device 002: ID 2001:3c1b
Bus 001 Device 001: ID 1d6b:0002
Bus 002 Device 001: ID 1d6b:0002
Bus 003 Device 001: ID 1d6b:0002
Bus 004 Device 001: ID 1d6b:0002
Bus 005 Device 001: ID 1d6b:0001
Bus 006 Device 001: ID 1d6b:0001
Bus 007 Device 001: ID 1d6b:0001
Bus 008 Device 001: ID 1d6b:0001
I hope you can get it to work.
Thanx
Martin
i need to buy a new wifi, can someone confirm me that this works on vu+,
http://www.tvbox.lt/sat-priedai/392-amiko-wln-870.html
Thank you.
@angelofsky1980
using bm750 driver i can access via ftp and telnet to my zero ... but from zero i can't reach internet and my local ...
do i miss something ? (probably yes, because i'm not an IT and i'm a newbie with BH).
Thanks and hope this isn't a necropost ...
