Ralink 3070/3370/5370/5372 driver for new Vu+ kernel
Hi angelofsky1980,
when I rt3070_2.5.0.3-r4-bh0_vusolo for WUSB54GC, and plugged my dongle, It didn't work. But I think I deleted Rtl8721u from my set, that it briefly worked. but when I restarted my set, I lost the wifi connection. The set recognized my dongle as rt2800usb. I reinstalled my Image, now I can't remove Rtl8721u from my set. can you help me please . My image currently is BH 2.0.3
I have since been able to connect to the net, but every time I restart the box or switch on and off I lose the connection
hi all, top forum. sorry for noobie question how do i download the rt5370 ipk from this site? thanks mosssat
Hi angelofsky1980
I am using Blackhole 2.1.1 Enigma2 image
wifi usb not working. let you know i send you usb wifi telenet results
# lsusb
Bus 002 Device 002: ID 148f:5370
Bus 001 Device 001: ID 1d6b:0002
Bus 002 Device 001: ID 1d6b:0001
Please resolve this driver problem.
Thanks Kind regards
Did you get these working in the end?
Hello, i `m a fresh user of VU+ Zero and i install latest Black Hole (3.0.2.J) on it. I have Linksys wireless dongle
Linksys WUSB600N v2 (Ralink RT3572) Is ther any chance to works this dongle with this image ??
In this thread there is the IPK for all Vu+ boxes that contains Ralink driver chipset.
Installation instructions:
a) put the IPK into a USB pendrive and connect it to your box. You will have the possibility to install IPK directly.
b) put the IPK into /tmp folder of your box and use the "Manual install IPK package" from BH Green Panel -> Yellow Button.
Supported devices will be avaiable on the second post of this thread.
Drivers avaiable! Make post here with feedback, please!
thanks for these
