Ralink 3070/3370/5370/5372 driver for new Vu+ kernel
In this thread there is the IPK for all Vu+ boxes that contains Ralink driver chipset.
Installation instructions:
a) put the IPK into a USB pendrive and connect it to your box. You will have the possibility to install IPK directly.
b) put the IPK into /tmp folder of your box and use the "Manual install IPK package" from BH Green Panel -> Yellow Button.
Supported devices will be avaiable on the second post of this thread.
Drivers avaiable! Make post here with feedback, please!
Tank you very much
thanks
thx..
Hi angelofsky1980
I am using Blackhole 2.1.1 Enigma2 image
wifi usb not working. let you know i send you usb wifi telenet results
# lsusb
Bus 002 Device 002: ID 148f:5370
Bus 001 Device 001: ID 1d6b:0002
Bus 002 Device 001: ID 1d6b:0001
Please resolve this driver problem.
Thanks Kind regards
THX
OK
Hi!
Is there an ipk package available - driver for RT5372 chip adapters? I have ASUS USB-N14 adapter and my Vu+ UNO4K SE (BH3.0.5.) doesn't see and recognize it.
Can you help on this?
Or - which are recomended wifi adapters for Uno 4K SE?
I have 2 wireless dongles (ASUS AC50)Ralink RT2870 and TL-WN823N V2(Realtek RTL8192EU) they don't work on VU+ UNO 4k...
Any help?
bonsoir
je suis connecté au LAN câblé dans mon menu il y a pas de LAND wifi je suis BH 2.1.7
comment je doit faire ?
Hello Folks,
I own a VU+ Zero running Black Hole 3.0.5 and a Tenda Wifi stick, driver Ralink 5370. Could anyone please advise/provide driver I should Use ?
I already tried 3070 for solo but did not work.
Thanks in advance
[QUOTE = "angelofsky1980, post: 145567, membre: 6"] Dans ce sujet, il y a l'IPK pour toutes les boîtes Vu + qui contient le chipset du pilote Ralink.
Instructions d'installation:
a) mettez l’IPK dans une clé USB et connectez-le à votre boîte. Vous aurez la possibilité d'installer directement IPK.
b) placez le dossier IPK dans / tmp de votre boîte et utilisez le "package IPK d'installation manuelle" de BH Green Panel -> bouton jaune.
Les appareils pris en charge seront disponibles sur le deuxième message de ce sujet.
Pilotes disponibles! Faites un post ici avec les commentaires, s'il vous plaît! [/CITATION]
jes for vu+solo
[QUOTE = "angelofsky1980, post: 145567, member: 6"] In questa discussione c'è l'IPK per tutte le caselle Vu + che contiene chipset driver Ralink.
Istruzioni per l'installazione:
a) inserisci l'IPK in una chiavetta USB e collegalo alla tua scatola. Avrai la possibilità di installare direttamente IPK.
b) metti l'IPK nella cartella / tmp della tua scatola e usa il "Pacchetto IPK di installazione manuale" da BH Green Panel -> Pulsante Giallo.
I dispositivi supportati saranno disponibili sul secondo post di questa discussione.
Driver disponibili! Crea un post qui con feedback, per favore! [/CITAZIONE]
grazie
