Ralink 3070/3370/5370/5372 driver for new Vu+ kernel
In this thread there is the IPK for all Vu+ boxes that contains Ralink driver chipset.
Installation instructions:
a) put the IPK into a USB pendrive and connect it to your box. You will have the possibility to install IPK directly.
b) put the IPK into /tmp folder of your box and use the "Manual install IPK package" from BH Green Panel -> Yellow Button.
Supported devices will be avaiable on the second post of this thread.
Drivers avaiable! Make post here with feedback, please!
thanks. i will work it in openatv
thank u very much
Will test and see
tnx
vou testar wireless pen amiko Ralink 5370 problema vu+ zero BH 3.0.9 não funciona
VOu testar
[QUOTE = "angelofsky1980, post: 145567, member: 6"] In questa discussione c'è l'IPK per tutte le caselle Vu + che contiene chipset driver Ralink.
Istruzioni per l'installazione:
a) inserisci l'IPK in una chiavetta USB e collegalo alla tua scatola. Avrai la possibilità di installare direttamente IPK.
b) metti l'IPK nella cartella / tmp della tua scatola e usa il "Pacchetto IPK di installazione manuale" da BH Green Panel -> Pulsante Giallo.
I dispositivi supportati saranno disponibili sul secondo post di questa discussione.
Driver disponibili! Crea un post qui con feedback, per favore! [/CITAZIONE]
grazie
thanks
i need driver for
{USB_DEVICE(0x148F,0x5370)}, /* Ralink 5370 */
for Black Hole 3.0.5 for vu+ zero 4k. I need .ipk for install.
Hello, I have a problem, I bougth one pen WI-FI USB with chipset Ralink RT5370, but my box Enigma 2 Technomate TM3-Nano d'ont acepted this pen
someone can help me please,
thank you
M.Matias
