registrare
riflreshato da capo obh 04 pulita formattato hdd verificato i percorsi registrazione corretta, adesso vedo anche il contenuto della cartella media/movie ma la registrazione e sempre size 0
allego risultato comando putty/telnet
root@vuultimo:~#djmount /media/upnp fuse.djmount ro,nosuid,nodev,relatime,user_id=0,group_id=0 0 0nfsd /proc/fs/nfsd nfsd rw,relatime 0 0/etc/auto.network /media/autofs autofs rw,relatime,fd=6,pgrp=611,timeout=5,minproto=5,maxproto=5,indirect 0 0devpts /dev/pts devpts rw,relatime,gid=5,mode=620 0 0tmpfs /var/volatile tmpfs rw,relatime 0 0/dev/sdb1 /media/usb ext4 rw,relatime,data=ordered 0 0/dev/sda1 /media/hdd ext4 rw,relatime,data=ordered 0 0tmpfs /media tmpfs rw,relatime,size=64k 0 0sysfs /sys sysfs rw,relatime 0 0proc /proc proc rw,relatime 0 0devtmpfs /dev devtmpfs rw,relatime,size=137112k,nr_inodes=34278,mode=755 0 0ubi0:rootfs / ubifs rw,sync,relatime 0 0rootfs / rootfs rw 0 0root@vuultimo:~# cat /proc/mounts
allego i menu rifatti spero in meglio
ridato comando risultato diverso..
root@vuultimo:~#-sh: cat/proc/mounts: No such file or directoryroot@vuultimo:~# cat/proc/mountsLast login: Tue Jun 7 12:49:18 CEST 2016 on pts/0
rifatto
root@vuultimo:~# 0 djmount /media/upnp fuse.djmount ro,nosuid,nodev,relatime,user_id=0,group_id=0 nfsd /proc/fs/nfsd nfsd rw,relatime 0 0 oto=5,maxproto=5,indirect 0 0 /etc/auto.network /media/autofs autofs rw,relatime,fd=6,pgrp=612,timeout=5,minpdevpts /dev/pts devpts rw,relatime,gid=5,mode=620 0 0 tmpfs /var/volatile tmpfs rw,relatime 0 0 /dev/sdb1 /media/usb ext4 rw,relatime,data=ordered 0 0 /dev/sda1 /media/hdd ext4 rw,relatime,data=ordered 0 0 tmpfs /media tmpfs rw,relatime,size=64k 0 0 sysfs /sys sysfs rw,relatime 0 0 proc /proc proc rw,relatime 0 0 devtmpfs /dev devtmpfs rw,relatime,size=137112k,nr_inodes=34278,mode=755 0 0 ubi0:rootfs / ubifs rw,sync,relatime 0 0 rootfs / rootfs rw 0 0 root@vuultimo:~# cat /proc/mounts
rec su sat e dtt e tutto ok solo iptv nn va un amico mi ha suggerito che sono i driver della vu per la versione ultimo che mancano
ma mi chiedo e possibile che sia solo un problema mio e nn ce nessun altro
per la parte rec. iptv a forza deve trattarsi di un demon esterno a enigma2.
Potrebbe essere che non sia implementato sul tuo box, un a conferma te la potrebbe dare solo chi ha un box uguale al tuo
L'output del comando che ti ho invitato a postare su un box normale, è di questo tipo:
vusolose login: root
Password:
root@vusolose:~# cat /proc/mounts
devtmpfs /dev devtmpfs rw,relatime,size=286116k,nr_inodes=71529,mode=755 0 0
/etc/auto.network /media/autofs autofs rw,relatime,fd=6,pgrp=515,timeout=5,minpr
fusectl /sys/fs/fuse/connections fusectl rw,relatime 0 0
//192.168.178.10/Harddisk /media/net/HarddiskVUSOLO4K cifs rw,noatime,vers=1.0,c
ache=strict,username=guest,domain=VUSOLO4K,uid=0,noforceuid,gid=0,noforcegid,add
r=192.168.178.10,unix,posixpaths,acl,rsize=1048576,wsize=65536,actimeo=1 0 0
root@vusolose:~#
ti avevo invitato a questo, per vedere se hai qualche device RO (read only)
una ne hai, ma non so manco che sia ..
ciao
ti ringrazio per il tempo che mi hai dedicato
mi meraviglio che chi possiede un vu ultimo nn intervenga dicendo la sua ...bo mistero ...
novità insanity ?? sei riuscito a fare il test ..
nel frattempo ho ridato il comando e stavolta mi sembra corretta la risposta
fusectl /sys/fs/fuse/connections fusectl rw,relatime 0 0 nfsd /proc/fs/nfsd nfsd rw,relatime 0 0 oto=5,maxproto=5,indirect 0 0 /etc/auto.network /media/autofs autofs rw,relatime,fd=6,pgrp=564,timeout=5,minpdevpts /dev/pts devpts rw,relatime,gid=5,mode=620 0 0 /dev/sdb1 /media/usb ext4 rw,relatime,data=ordered 0 0 /dev/sda1 /media/hdd ext4 rw,relatime,data=ordered 0 0 tmpfs /var/volatile tmpfs rw,relatime 0 0 tmpfs /media tmpfs rw,relatime,size=64k 0 0 sysfs /sys sysfs rw,relatime 0 0 proc /proc proc rw,relatime 0 0 devtmpfs /dev devtmpfs rw,relatime,size=137112k,nr_inodes=34278,mode=755 0 0 ubi0:rootfs / ubifs rw,sync,relatime 0 0 rootfs / rootfs rw 0 0 root@vuultimo:~# cat /proc/mounts
purtroppo no, ma non ti avevo dimenticato, solo che non ho trovato nessuno con il tuo box ..
mi spiace, ma non disperiamo !!
