Review Vu+ Solo2 By Black Hole
Thanks for this review.I have a dreambox 800HD PVR (5 years ago ) and i wish to send a Solo2.
I want to flash OPENpli image but now with BH, I doubt...
I do not like internal HDDs producing additional heat in the box and I don't like 2.5" . How can I use SATA - eSATA cable with Solo2? Make a black hole in the box? Remove useless SCART?
Y
Your warranty will be gone when doing either one!! That is for sure.
I do like internal 2.5" drives: They are silent, produce little heat and don't load the PSU a lot.
I have installed fresh Plextor M5S 128 GB SSD, but BlackHole 2.02 did not even noticed it after several rebootings. Thanks God, I had VTI in Meoboot that determined the SSD and enabled me to initialize it. Then SSD appeared in BH.
All things are possible,
But what does it have the image in Mutiboot,
with those in flash and HDD/SSD
And recognizing the drive.
That has no relationship with the HDD in VTI/multiboot.
It was still something else.
Hi
I have vu solo and i want to upgrade to solo 2
I have question about it
1- picture quality is very important for me and I want know that Which one looks better about it ?
vu solo 2 or DB 800 hd or DB 7020 hd
2-do you think that the picturs qualitys solo2 is Similar solo or solo 2 is better than solo ? ( both of them with Black hole image )
3- What are the problems solo2 ? ( for example : searching or finding frequency or anythings )
thanks a lot for answer me
And what about SSD support (TRIM, etc)? (I want to use it for fast meobooting).
As Matrix said, It was something else ;) .
What else? You've been installing new SSD HDD on running meoboot configured system (Linux based enigma2). Are you surprised that BH didn't detect it?. Because of reason of stability.
If you want to configure stable BH SSD HDD with Meoboot, you should at first install fresh BH, next install SSD HDD (your SSD HDD will be recognized at 99,99%) and afterthen Meoboot.
It sounds very strangely for me. Imagine, I like to install a new SSD (HDD) in multiboot Windows system ( Win7 and Win8) and somebody recommends me first to reinstall both Windows :haha:
my friend... try using telnet or SSH console, you can do so with their hands.
1º check SSD
# fdisk -l
result example....
Disk /dev/sda: 500.1 GB, 500107862016 bytes
255 heads, 63 sectors/track, 60801 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Device Boot Start End Blocks Id System
/dev/sda1 1 60802 488386580 83 Linux
root@vusolo2:~#
now format SSD EXT2 please... EXT3 "possible instability"
# /sbin/mkfs.ext2 -T largefile -m0 /dev/sda1
now... mount
# mount /dev/sda1 /media/hdd
Fix new folder /media/hdd/movie and CHMOD 777
:oops:
attachment.php
This way is for Linux experts. I need friendly BH GUI with plug'n'play function. 99 % of users need the same thing. As I said before, VTI can do that. Why BH cannot?
You are not in Windows :haha:. You are in Black Hole Linux based Enigma2 :yahoo:.
I repeat, configuration of internal HDD is beginning of software installation. Flashing fresh BH, installing internal HDD, configuring system, Meoboot installation. If you don't like this BH procedure, don't use BH. BH has own philosophy of managing peripherals to be more stable.
No comment about 99% of users (you didn't wrote of what).
Do you like VTI? Use VTI and not BH. It's up to you.
I like various images and various girls :grin: and want them have friendly interfaces :)
And U like stability despite of their (inter) faces ?
Use Meoboot and install all available images would be my suggestion. You then can enjoy all the girls you like without even getting complaints from any of them for doing so. Have fun (I hope you got truckloads of free time).
Oh yes let us know your findings via detailed reporting per element compared.
I already told you that your problem with SSD/HDD has nothing to do with image
Your argument SSD is activated after VTI only confirms.
Multiboot image can not activate HDD in flash image.
Hi
Vu+ Solo have better PQ then Solo2, I own solo2 and still wait for PQ improvement..........
