Review Vu+ Solo2 By Black Hole
Have you tried to adjust your settings in system > video enhancement settings?
I'm using default config for bh and can't complain about picture quality.
But my tv is not Sony...
I already try everywhere and at the moment can not react objective:) anymore, this is why I ask settings, but on default settings my sony not show clear picture, how You set autoresolution?
Anybody know if is possible or even could be possible to use hdmi ethernet on vu+solo2?
I meant, connect the TV and the receiver with an hdmi ethernet cable and they share the internet between them
I haven't seen the HDMI 1.4 specs .... I suggest to write directly to Vu+ about your request :)
As Far as i am aware there is no HDMI 1.4 this branding was done away with last year and HDMI now comes in 5 Standards only
  • Standard HDMI Cable – up to 1080i and 720p
  • Standard HDMI Cable with Ethernet
  • Automotive HDMI Cable
  • High Speed HDMI Cable – 1080p, 4K, 3D and deep color
  • High Speed HDMI Cable with Ethernet
Hi there
I'm getting my Solo2 tomorrow and before even flashing BH I was wondering if any of you guys could explain the right way to phisically install the hhd drive inside the box.
I've seen that on most reviews including this one you place the hdd on top of the bracket with the letterings facing up but I've seen others where they actually place it inside the bracket with the letterings facing down.
Probably not really an issue but for neatness sake, which is the right way ??
Cheers
Obviously. I reckon I'll have to check it myself when I get my hands on it and then decide which way it looks right for me. Thanks anyway.
