Request RTL2832 + R820T (tuner) support
Can you try to connect your USB DVB device to an external powered USB hub?
Can be useful also a "dmesg" output when you reboot your box
First thanks for your help, and sorry for my English because I am Spanish.
I've put a hub and so does not work, I do recognize the vuduo, and I made the dmesg, but not how to copy the entire dcc text to paste here. A greeting and thank you very much. I have returned to make a blind search, and remains the same, the signal very well, but it looks pixelated. See if you like copy all the text and stick it here.
You must use a very ssh/telnet program like Putty and next copy/paste the very long "dmesg" output here after a reboot of your box
ok, I did it from windows telnet, this is the result. Hopefully you can help. A greeting and thanks for everything really, you're very kind.
ALSA device list:
No soundcards found.
TCP cubic registered
lib80211: common routines for IEEE802.11 drivers
lib80211_crypt: registered algorithm 'NULL'
EBI CS0: setting up NAND flash (primary)
mtd->oobsize=0, mtd->eccOobSize=0
NAND_CS_NAND_XOR=00000001
B4: NandSelect=40000101, nandConfig=55042200, chipSelect=0
brcmnand_read_id: CS0: dev_id=ecf10095
After: NandSelect=40000101, nandConfig=55042200
Block size=00020000, erase shift=17
NAND Config: Reg=55042200, chipSize=128 MB, blockSize=128K, erase_shift=11
busWidth=1, pageSize=2048B, page_shift=11, page_mask=000007ff
BrcmNAND mfg ec f1 Samsung K9F1G08U0A 128MB on CS0
Found NAND on CS0: ACC=d3000000, cfg=55042200, flashId=ecf10095, tim1=4232222d,
tim2=00000d94
BrcmNAND version = 0x0201 128MB @00000000
Found NAND flash on Chip Select 0, chipSize=128MB, usable size=128MB, base=0
brcmnand_scan: B4 nand_select = 40000101
brcmnand_scan: After nand_select = 40000101
page_shift=11, bbt_erase_shift=17, chip_shift=27, phys_erase_shift=17
Brcm NAND controller version = 2.1 NAND flash size 128MB @18000000
ECC layout=brcmnand_oob_bch4_4k
brcmnand_scan: mtd->oobsize=64
brcmnand_scan: oobavail=50, eccsize=512, writesize=2048
brcmnand_scan, eccsize=512, writesize=2048, eccsteps=4, ecclevel=15, eccbytes=3
-->brcmnand_default_bbt
brcmnand_default_bbt: bbt_td = bbt_main_descr
Bad block table Bbt0 found at page 0000ffc0, version 0xFF for chip on CS0
Bad block table 1tbB found at page 0000ff80, version 0xFF for chip on CS0
nand_read_bbt: Bad block at 0x03e40000
nand_read_bbt: Bad block at 0x04820000
Creating 7 MTD partitions on "brcmnand.0":
0x000000000000-0x000007600000 : "rootfs"
0x000007600000-0x000007a00000 : "kernel"
0x000007a00000-0x000007c00000 : "boot"
0x000007c00000-0x000007d00000 : "cfe"
0x000007d00000-0x000007d80000 : "mac"
0x000007d80000-0x000007e00000 : "env"
0x000007e00000-0x000007f00000 : "nvm"
UBI: attaching mtd0 to ubi0
UBI: physical eraseblock size: 131072 bytes (128 KiB)
UBI: logical eraseblock size: 126976 bytes
UBI: smallest flash I/O unit: 2048
UBI: VID header offset: 2048 (aligned 2048)
UBI: data offset: 4096
usb 1-1: new high speed USB device number 2 using ehci-brcm
ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
ata2.00: HPA detected: current 976771055, native 976773168
ata2.00: ATA-8: SAMSUNG HD501LJ, CR100-12, max UDMA7
ata2.00: 976771055 sectors, multi 0: LBA48 NCQ (depth 0/32)
ata2.00: configured for UDMA7
scsi 1:0:0:0: Direct-Access ATA SAMSUNG HD501LJ CR10 PQ: 0 ANSI: 5
sd 1:0:0:0: Attached scsi generic sg0 type 0
sd 1:0:0:0: [sda] 976771055 512-byte logical blocks: (500 GB/465 GiB)
sd 1:0:0:0: [sda] Write Protect is off
sd 1:0:0:0: [sda] Mode Sense: 00 3a 00 00
sd 1:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO
or FUA
sda: sda1
sd 1:0:0:0: [sda] Attached SCSI disk
UBI: max. sequence number: 659
UBI: attached mtd0 to ubi0
UBI: MTD device name: "rootfs"
UBI: MTD device size: 118 MiB
UBI: number of good PEBs: 942
UBI: number of bad PEBs: 2
UBI: number of corrupted PEBs: 0
UBI: max. allowed volumes: 128
UBI: wear-leveling threshold: 4096
UBI: number of internal volumes: 1
UBI: number of user volumes: 1
UBI: available PEBs: 0
UBI: total number of reserved PEBs: 942
UBI: number of PEBs reserved for bad PEB handling: 9
UBI: max/mean erase counter: 3/0
UBI: image sequence number: 1814375433
UBI: background thread "ubi_bgt0d" started, PID 45
UBIFS: parse sync
UBIFS: mounted UBI device 0, volume 0, name "rootfs"
UBIFS: file system size: 116563968 bytes (113832 KiB, 111 MiB, 918 LEBs)
UBIFS: journal size: 9023488 bytes (8812 KiB, 8 MiB, 72 LEBs)
UBIFS: media format: w4/r0 (latest is w4/r0)
UBIFS: default compressor: lzo
UBIFS: reserved for root: 0 bytes (0 KiB)
VFS: Mounted root (ubifs filesystem) on device 0:12.
Freeing unused kernel memory: 236k freed
NET: Registered protocol family 10
procmk_init
dvb_bcm7335: module license 'Proprietary' taints kernel.
Disabling lock debugging due to kernel taint
DVB: registering new adapter (bm750)
bcm7335: hotplug_callback():
Hotplug - status.connected 1
Hotplug - connecting HDMI to display 0xe
brcm_demux_init: $Id: bcm7335_demux.c,v 0.6 $
[VID]: <6>bcm7335_video_init
[AUD]: <6>bcm7335_audio_init
DVB: registering adapter 0 frontend 0 (BCM7335 FE)...
[MPVR]: >> misc_pvr_init
input: dreambox advanced remote control (native) as /devices/virtual/input/input
0
[LCD]: registered
[CI]:-BM750_PCB_2_1
[CI]: registered ci0
[CI]: registered ci1
[DFP]: registered dbox fp
[DFP]: bcm7335_i2c_write: Error 1114113
[DFP]: bcm7335_max_i2c_write: Error 1114113
[DFP]: Scart 4707 is found 4
[SC]: registered sci0
[SC]: registered sci1
system_time_set wakeup mode get
system_time_set wakeup mode get 0xc1
udevd (116): /proc/116/oom_adj is deprecated, please use /proc/116/oom_score_adj
instead.
WARNING: You are using an experimental version of the media stack.
As the driver is backported to an older kernel, it doesn't offer
enough quality for its usage in production.
Use it with care.
Latest git patches (needed if you report a bug to linux-media@vger.kernel.org):
Custom Black Hole build
usbcore: registered new interface driver dvb_usb_rtl28xxu
usb 1-1: dvb_usb_v2: found a 'Realtek RTL2832U reference design' in warm state
usb 1-1: dvb_usb_v2: will pass the complete MPEG2 transport stream to the softwa
re demuxer
DVB: registering new adapter (Realtek RTL2832U reference design)
usb 1-1: DVB: registering adapter 1 frontend 0 (Realtek RTL2832 (DVB-T))...
r820t 0-001a: creating new instance
r820t 0-001a: Rafael Micro r820t successfully identified
usb 1-1: dvb_usb_v2: 'Realtek RTL2832U reference design' successfully initialize
d and connected
[VID]: VIDEO_SET_STREAMTYPE 0
[VID]: VIDEO_SELECT_SOURCE 1
[VID]: VIDEO_PLAY 1 2 0
[VID]: VIDEO_CONTINUE 1 1
[VID]: VIDEO_CLEAR_BUFFER 1 1 0
EXT3-fs (sda1): error: couldn't mount because of unsupported optional features (
240)
EXT2-fs (sda1): error: couldn't mount because of unsupported optional features (
240)
EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[VID]: VIDEO_STOP 0 1
[VID]: VIDEO_SELECT_SOURCE 0
Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
svc: failed to register lockdv1 RPC service (errno 124).
DVB: registering adapter 0 frontend 0 (Realtek RTL2832 (DVB-T))...
[CI]:ci_dev_open
[CI]:Opening A GPIO's for 7335 platform
[CI]:Opening A GPIO's for 7335 platform....done
[CI]:entering.. A NEXUS_DvbCi_Open
[CI]:NEXUS_DvbCi_Open done..
[CI]:Installing callbacks
[CI]:Forcing card check
[CI]:Card insertion status changed
[CI]:Opening B GPIO's for 7335 platform
[CI]:Opening B GPIO's for 7335 platform....done
[CI]:entering.. B NEXUS_DvbCi_Open
[CI]:Card B insertion status changed
[CI]: CI interface initialised
[CI]:ci1_dev_open
[CI]:NEXUS_Remux_Start CI0 0 0
[CI]:>>close_mpod tuner:0
[CI]:remux stop
[CI]:get_remux_startcnt() count : 1
[CI]:>>close_mpod tuner:1
[CI]:remux stop
[CI]:get_remux_startcnt() count : 0
eth0: no IPv6 routers present
[AUD]: AUDIO_SET_MUTE 0
[AUD]: AUDIO_SET_MIXER -2041774616
[AUD]: AUDIO_SET_MIXER : amixl 0, amixr 0
[AUD]: AUDIO_SET_MIXER : next left volume 0, right volume 0
[AUD]: AUDIO_SET_MIXER : next left volume -200, right volume -200
FE tune
[AUD]: AUDIO_SET_BYPASS_MODE 1
[AUD]: downmix 0 state : 0
[AUD]: AUDIO_PAUSE 1
[AUD]: AUDIO_PLAY 1 decoder start : 0
[VID]: VIDEO_FREEZE 1 0
[VID]: VIDEO_PLAY 1 2 2
[VID]: VIDEO_SLOWMOTION 0 1
[VID]: VIDEO_FAST_FORWARD 0 1
[AUD]: AUDIO_CONTINUE 1 1 audio pid_hndl : 0xc0c1316c
[AUD]: setting mute : 0
[AUD]: AUDIO_CHANNEL_SELECT 0
[VID]: VIDEO_STOP 1 1
[AUD]: AUDIO_STOP 1
[AUD]: AUDIO_CONTINUE 1 0 audio pid_hndl : 0x0
[AUD]: AUDIO_CONTINUE:bcm7335->audio_pid_hndl is null 0 0
dvb_demux_feed_del: feed not in list (type=0 state=0 pid=ffff)
[AUD]: AUDIO_STOP 1
[AUD]: AUDIO_STOP 1
FE tune
root@bm750:~#
I think I've equivocad, when I do dmesg, I guess I'll have to have put a Freeview channel, right?.
I did and this is what I get. Thanks for everything.
or FUA
sda: sda1
UBIFS: parse sync
procmk_init
0
[LCD]: registered
[CI]:-BM750_PCB_2_1
instead.
Use it with care.
re demuxer
d and connected
240)
240)
[CI]:ci_dev_open
[CI]:ci1_dev_open
[CI]:remux stop
[CI]:remux stop
FE tune
[AUD]: AUDIO_STOP 1
[AUD]: AUDIO_STOP 1
[AUD]: AUDIO_STOP 1
FE tune
[AUD]: AUDIO_STOP 1
root@bm750:/#
IS well, everything is fine ..?
I have RTL28xx devices ... I've one who uses E4000 tuner and it's quite bad ...
From your log seems all correct.t
I'll re-test my rtl28xx device with latest BH image to check if the problem is related to R820T or other parts of driver
