Rytec EPG
I have problems with Rytec D+ Spain epg......it gives me green screen and E2 restart every time i try to do a manual download for that provider!
Every other provider works ok...only problem is with Dplus!...Any idea why? Thank you!
Thanks @Zupy for advice....i tried to download only D+ epg, it shows as downloading, but no epg data appears after download. Colud it be because i have epg.dat on usb and not on hdd?
Which image do you use?
Normally the place of epg.dat does not matter.
Willy
I have a problem with D + provider - does not appear after download.
Anyone with similar problems like mine??
Hi friend will be possible add suport for polish tv N now is totaly no suported by you.
Im find next error please look to polish tv chanell FOX HD on this chanell is only epg for 24 hours chanell is broadcast by Cyfra+
Hi, can you tell me what files go where in Nabilosat Black Hole - v0.12, looking to get sky uk epg up and running.
Dear Rytec
I uploded configuration in /etc and manually installed "enigma2-plugin-extensions-xmltvimport_1.0-r36_mipsel.ipk" in my vu+solo but i can't see anything in my green panel . I am using BH image 1.6.2 would u please explain if there is anything else i should do and how to use your plugin ?
Hi colleagues !
In last 2 days for me not working rytec EPG via Crosepg. I used 5 providers : Sky It,Sky Uk,D+,Sky De and Ex-Yu.
CrossEpg downloaded epgs but not show any,i tried several times. What can be a problem ?
Not working Sky it rytec EPG via Crosepg. What is a problem ? After donloaded epgs no epgs in settings list.
Hi, I have a Vu+uno and I have downloaded the Blackhole image. Can you please tell me in dummy language how to set up EPG?
I have tried to download Rytec but nothing has happened.
I would appreciate your help,
Best regards,
Colin
Best regards,
Colin
Press blue botton, red botton, select epg you need, press green botton, yellow botton to download.
