S k i n F a c t o r y 6
Ohhhhhhhhhhhhhhhh!!!!!!!!!!!!!!!
This is a magnificent, you have to give me to test this if you almost do not cast it out:)
After all,the beautiful icons-finally, what was missing everything to be flawless!
Keep a variation of blue color as the cursor, do not go too far into the green, it's much nicer way.
Excellent!
:D
Matrix10’s Registered & Protected Graphic
(Matrix10 is an alias name) Edit details | Delete copyright Copyright:All Rights Reserved
Fingerprint:Show digital fingerprint
03e553cb3afbca90ad9232d940f14ebeecd02bb33159fc1bba8f8c26fe1823ef
Title:OSD
Description:Skin graphic
MCN:CXRRF-U2HPX-P7AH2
Please tell us the time will be this wonderful skin, teeth that already have long, heh, heh. Greetings
There is still much work
I have spent many hours on the coding.
As you know I do not like a lot of icons in skin.
Besides I like the standard Menu/Panels in the middle
of TV screen.
So we'll have to do another version,in my personal style.
As you can see the OSD have some new elements
more depth I will probably use in the next sub version that I will make in my style.
I think we will have several versions of this skin
is not even finished the first version. :thumbup:
This skin I coded again
Which means that the next version which I do in my personal style
be very fast.
Rgd MX
Fantastic, very, realy very nice skin, great job Matrix10.
I have to say thank very much to you for the time you spend to make beautifull skins (and not only) to us.
All the best to you and to all Black Hole team.
Hi Matrix,
You continue with a great job, I love it! :wub:
Some suggestions for Movie Infobar:
- Keep same Hour format than the Channel Infobar
- Keep same position of "Dolby Digital" image like in the Channel Infobar
- Keep same position of "16:9" image like in the Channel Infobar
- Add "HD" image in same position like in the Channel Infobar and activate it if the movie is in HD :idea:
- Add "VIDEO TEXT" image in same position like in the Channel Infobar and activate it if it is used a subtitle file :idea:
- Keep same position of "screen size" info (1440x1080) like in the Channel Infobar
- Keep same position of "date" info (13.01.2011) like in the Channel Infobar
- Add new file information to 2nd line of Infobar: File directory, complete File name,... :idea: :thumbup:
Thanks
Hi Matrix,
Thanks
All this must be tested
in some of the following versions
I'm not sure If we can use all this in coding,
and if we can use some information will have to be moved to another position in OSD .
Skin Factory 6 V1 you can download and test.
Skin Factory 6 BH BH1.4.1/1.4.2/1.4.3 V1 (Black Hole E2)
Version 1 on Our server
Menu panels in the middle of the TV screen.
Very fast skin and Menu panels .
Skin Factory 6 S BH BH1.4.1/1.4.2/1.4.3 V1 (Black Hole E2)
Main Menu Panels on the left side of the TV screen
Rgd MX
p.s Pls first +- 30 PPL download skins agn .I made a small update for Radio Infobar and Radio channel list ,fixed small bugs .
.If you have cut off the lower part of Radio info OSD panel .
and you were among the first to download the file Download file again.
For this skin you can use white picons from our server , look very nice.
dc0a5774875cbb707c8aa4d9279ce3ef72cad113be3ed0d0cf08b4940f3d2a4a
Title:Skin Factory 6 skins
Description:Skin Factory 6 skins
MCN:CMW8L-GXE1M-DDDHM
