S k i n F a c t o r y 6
Skin Factory 6 V1 you can download and test.
Skin Factory 6 BH BH1.4.1/1.4.2/1.4.3 V1 (Black Hole E2)
Version 1 on Our server
Menu panels in the middle of the TV screen.
Very fast skin and Menu panels .
I like it.....
Great, very nice skin, I'm thankful for this skin is on BH server already, I have it now.
Thank you very much master Matrix10, you're big.
Both versions are very beautiful ! Great job Maestro !
You could post here some picture with changes in panels if is it viewable.
Thanks,
Nothing special
I just corrected the position of some of the panels that were too low.
Rgd MX
Important skin UPDATE V 3 on our image server
Change in all Main Panels
Skin Factory 6 BH BH1.4.1/1.4.2/1.4.3 V3 (Black Hole E2)
Thanks
Martix10 spoil the vu+ duo, others they will not find what they do
I congratulate vu+ duo that have Matrix10 to develop it
Master Matrix10, you still making excellent job, thank you for your hard work.
It's not important, but the digital clock in infobar have not seconds, it's your choice or you will update later the digital clock with seconds in infobar?
No is my choice .I think that it is not necessary.
I try to limit the number of information in OSD.
Thanks for nice feedback.
Rgd MX
Rgd MX
Ok, thank you for your fast reply.
I prefer info bar with seconds but like I said, it's not very important, realy important is the final result of this fantastic skin that is realy beautifull, it's the skin I use right now.
