Is the vu+ ultimo compatible with SATA 3 HDD?
Sent from my GT-I9100 using Tapatalk 2
Thanks..but which would you recommend?I haven't tested directly but should be.
Sent from my iPad using Tapatalk
Read here,Thanks..but which would you recommend?
I just need to get the best.
Is there a maximum capacity,i plan to go for 2TB...5400rpm or 7200rpm?..
Just a little confused.
Just read the above thread..WD doesn't compare to those???Read here,
http://www.vuplus-community.net/board/threads/hdd-size.5898/#post-48617
I like Seagate !
No> WD> has bad preformance... !
Read here,
I like Seagate !
Too late! I just ordered i just hope it's backward compatible with ultimo..NO! all vuPlus are all sata2!...
I'm sorry..
I read from somewhere that a device can be SATA 3 compatible and not SATA 3 capable...just like when you are copying a file from a pc that has usb 2.0 to an external Hdd that is usb 3.0,you are not gonna get that speed that usb 3.0 delivers..Usually HDDs are backward compatibles (like SATA-I and SATA-II disks) but I haven't tested directly
