Skins
HD Glass16 Ver. 9.56
Update 31.05.2015
- main code: acceleration, optimalized events timing
- added screen 52
- previews and extrascreens graphics updated in download
update is available online (setup and website)
thx @ shamann
HD Glass 16 Ver 9.72
- fix if all options from: Temp.HDD, CPU/Mem, Temp/RPM, Provider are disabled
#1.Post
HD Glass 16 Ver 9.76
- fix Channelsel. type: ZZPicon 4, PIP 4, PIG 4 in images based on OpenPLi
- changed options from "Enable ChannelSel. percent" and "Enable
ChannelSel. doubleline list" to "Enable ChannelSel. percent, picon" and
"ChannelSel. show channel number"
- updated pl, sk, cz, en, ru, de, it, uk, pt, tr, es, fa, al, ro, hu, nl, et
- help updated in download
- fix detection of tuner type in the name of channel if is enabled
- fix (DVB-T) convert Fq to channel number (fix for python 2.7.x and older)
- added full support and detection (DVB-C, DVB-T) for tp info in channel
selections screens (all types)
#1.Post
HD Glass 16 Ver 10.02
- download menu: added more satellites in option "Select" in some type of picons
- picons for satellites 27.5w,24.5w,22w,18w,15w,12.5w,11w,8w,7w will be added online later
thx @ shamann
Skin Kraven VB
thx @ Kraven, örlgrey & tomele
Konnte ihn zwar installieren und finde ihn unter plugins , aber leider kann ich nichts einstellen. Besser gesagt ich komm erst garnicht dahin,
nun kann ich nicht sagen ob er in open black hole funktioniert , jedenfalls in bh v2.1.7 keine chanche.
gruß
Skin Dreamy (blackhole edition) by Raskino
thx @ Raskino
Skin Dreamy ( blackhole edition) by Raskino ( dvbmedia.it )
Caratteristiche :- skin base ( dreamy atemio4you edition by mmark)
- BHdreamy compatibile dalla blackhole 2.1.4 e superiori
- distribuito in 3 versioni ( normale , con meteo , debug)
- Pics universe ( nuove grafiche e altre sistemazioni) _ thanks mmark
Dettagli sulle 3 versioni :
Bhdreamy ( no meteo)
BhdreamyM ( con meteo)
BhdreamyD ( versione debug *)
* Abbiamo deciso di rilasciare anche la versione debug per poter dare modo all'utenza di poter segnalare e collaborare per il miglioramento di questa skin per BH , la modalità debug contrassegna ogni pannello/finestra con dei numeri e quindi qualsiasi problema è di facile individuazione.
Changelog rev 1.1 :
wie kann man das wetter eistellen - mit yahoo plugin funzt es net auf der Vu Solo4k
der Dreamy Skin ist ein sehr guter Skin bis auf die Wetteranzeige
