skystar2
dlmlus
Hi guys
been looking around but can,t find an answer.
will the skystar2 usb+ work with the vu+ uno, i believe the
skystar2 is a rebranded tecnotrend 2400.
cheers
dlmlus
dpeddi
If you have this device, can you post vendor_id and product_id about this device?
You can get this information from windows in hardware manager.
Whit this information we can give you a better answer
dlmlus
cheers
this is what windows says.
TecnoTrend TT-connect S-2400 (BDA/8kB EEPROM) Properties
below is a link to this product, hope this helps and thanks for your time.
h==p://engl.technotrend.eu/2778/TT-connect__S-2400.html
dlmlus
angelofsky1980
BlackHole Driver Specialist
cheers
dlmlus
We need to know the hardware IDs of your device.
Into Windows, into Device Managment, double click your device, goto into "Details" tab and then select "Hardware ID" dropbox menu.
Copy & Paste all strings reported.
dlmlus
hi guys
this what it says under hardware id, hope it helps.
USB\VID_0B48&PID_3009&REV_0100
dlmlus
angelofsky1980
hi guys
dlmlus
Your device seems already supported by ttusb2 driver.
You need to install the package attached to this post (upload it to /tmp folder of your box; press GREEN button -> YELLOW button and then select Manual Install BH packages).
After that connect your USB device and reboot your box)
  • skystar2_firmware_bh.tgz
dlmlus
angelofsky1980 Thankyou very much, i will do as you say.
dlmlus
dlmlus
angelofsky1980 I will report back when tried and tested.
cheers
dlmlus
angelofthesky 1980 thank you very much for your guidance, i installed the firmware as you said and rebooted
the box but the skystar2 did not show up in the tuner config. i,ve decided i,m going to purchase the new twin
tuner uno/ultimo on sale now.
thanks once again for your time.
dlmlus
