Talk about EC168 driver
Ok.
You haven't enabled your USB tuner from USB Tuner Panel (2 x Blue).
Go into Blue Panel (2 x Blue), go to into USB Tuner Panel, if you have already downloaded and installed drivers (with Red button) you can enable it with Green Button and hope that appear the request to restart E2 :)
If "No supported devices" appear, please report again the three files you have already uploaded in the last two posts.
Thanks.
Good morning Angelofsky,
I did exactly,to the word, what you said above.
I installed the drivers for the EC168 and rebooted box, when prompted.
The box messages told me it was installed ok and told me to reboot to enable.
I did that. When i then went to usb panal, it was shown as working (in green)
I then went to the scan that tuner and it was showing 4 tuners in the menu, despite the stick been mono.
Anyway, i choose tuner c - then selected europe - then scanned in full.
I was shown a progress for scanning "unknown tuner" and no services were found.
I then did the same for tuner d - that reported the same - no services found?
I went back to the usb panal and tuner is named and is shown working?
I attach again the files that may help you
Thanks for all your assistance m8
  • dmesg.txt
    dmesg.txt
  • usb.txt
    usb.txt
  • lsmod.txt
    lsmod.txt
Ok.
Your last report is very good enough to evaluate the problem.
First of all: have you setted up your tuner on E2 tuner panel config to your geo location? (the panel is the one when you see tuner C and D :) and you should setup both tuners :) )
Seems that your device is a dual tuner device :)
In the tuner menu, the dvb-t is listed as "tuner unknown DVB-T" and shows "ENABLED"
Yes - i selected the tuner C and then had 3 further settings:-
1) Configuration Mode ------- "enabled/disabled" ---- ENABLED
2)Provider---------------------Iceland dvb-c/Australia/Europe dvb-t ---- EUROPE DVBT
3) Enable 5V for active antenna------------------ yes/no ------ NO
D tuner has exactly the same menu's and they are set the same as C tuner.
I go to the Service Searching - manual scan - here i select Tuner C - then choose type of scan Complete, then leave the 3 remaining options NO.
The tuner scans for channels but finds NO SERVICES
Thanks m8
Thanks m8
Have you tried the service scan with D tuner instead of C tuner? Same results?
Hi Angelofsky,
Is their anything else i need to do with the box, so that you can assist with my problem?
Are the drivers correct for this tuner. (EC168)
I did try other drivers but they were not recognised.
Thank you for your ongoing help, im sure we will get it working.
:confused:
Hi Angelofsky,
:confused:
Could you please open your device and post here some photos of chips?
I need detailed info about your device to try to solve the problem.
no problem m8 - ill disconnect everything and await your news...
i apologise if i am impatient - no way do i intend to rush you... we all know you work very hard for the team!
i will await your update as and when
thanks m8
Any luck Angel... i have had the usb tuner exchanged.
It is the same model and installs as above but the tuning for channels is zero.
There has to be an issue with the tuner drivers?:oops:
I've patched the EC168 driver for BH 1.6.2 Beta only.
Please use the last option from Usb Panel (EC168 EXPERIMENTAL) and report the dmesg output when you try to enable driver.
Please remember: I don't have a device to make personally tests so the driver probably doesen't work.
