Test skins
I wounder , how the skin will look with light green/green in place of blue.....:secret:!
May be the next one!
Hello Master,
Did you plan to add as an option EPG in second info bar like you did some time ago.....that was very handy, as in the dark the big OK button is easy to find.
It is the smallest problem
We must first have a well-coded skin
that we can make other minor variations .
Now I have to test and make panel
one by one.
And of course it is a lot of work.
All skins so far more or less use the black and dark backgrounds.
On the other hand we have here in almost the entire skin
a totally new approach to buttons and backgrounds of buttons.
All this must be good coded and put into a whole.
So skin is far more than the OSD info.
A BIG thanks to Matrix10 who is spending so many time just for our pleasure !
The skin.xml contains over 5000 lines to be written to call all these new colors of fonts and backgrounds.
All my respect Master ! :notworthy:
Friend Matrix10 to be online when the skin is that I have to put it in my impatience deco .. is that this sensational ... greetings ...
As you can see this is a very complicated coding.
In the same panel we have
PIG, Search History and Search in the same place in the same panel.
