transcoding setup
have you test the ports with <canyouseeme> ? in vuplayer settings tried to put transcoding function on? and to the ip settings you put your noip address?
its ok i fix
Here is how i get working on Vu duo 2 blackhole 3.0.2
Open webif enabled Yes
Show box name No
HTTP port Use your chosen port number ( make sure you open the port in router or modem NAT settings ).
Enable HTTP authentication No
Enable HTTPS Yes
HTTPS port Choose your port number
Enable HTTPS Authentication No
Require client cert No
Smart services Remaining No
Enable Parental control No
Add service name to stream information No
Kostalolo, did you set like this on webinfo plugin?
Poslato sa Huawei P8 lite
Hello. Why in my Solo SE with Black Hole I cannot get into advanced settings of transcoding ? Where I can set up resolution and otherb advanced settings ?
Hi,
I have a VU+ UNO 4K with a DVB-C FBC tuner, and when i try to make transcoding, in VLC appears always black... but if i try to do stream directly any channel, works well! What can i do to be able to do transcoding?
Thanks!
I have a IPTV subscription. Is it possible to stream these channels from the Duo2 to another Vu+ on the same lan?
