Ultimo VFD skin without Picon
@DanielFran
Sorry m8 but without a white needles we must use a white background as Matrix10 stated.
Here are the files of Vfd skin with Analog clock.
This is the final result.
In the .rar file are included:
White background for digital clock & date as in my previous post #15
and
15 different backgrounds for the clock.
How to use them, read the "Read me" in "Extra layouts" folder.
Regards hija31
The one with the SNR bar on the top from my first post please.
The other ones with analog clock, they can download from here in the forum.
Here is also the one that you made and maybe someone else will make another one.
Thanks in advance.
Thanks in advance.
Pls can you test before i put on the server.
(copy to /tmp install manual BH packages)
Thanks
@Matrix10
Tested this way.
Before testing I removed all my skin related files from : "fonts" & "vfd_icons" folder.
This way it be like someone new, who didn't have this skin on Ultimo but only standard skin.
Every thing went fine. All needed files are in the appropriate folder and skin installed and work fine.
It's O.K.
Thanks.
@Matrix10
Tested this way.
It's O.K.
Thanks.
Ok i have put skin on the BH server
Skins download with preview
LCD skin VU Ultimo @hija31 (Black Hole OE 2.0)
@hija31 could you pls make SD icon to show as well when you zap to a standard channel just like the HD ones.
Thanks for the hard work.
Sent from my GT-I9100 using Tapatalk 2
i hope in the future we will have choise to select who White background digital clock & date or Diferent Clock backgrounds we will like use
dear Matrix10 file in black hole addons server do not have inside this clock and white background for digital clock & date
it is to simple please check it
@sat gr
What did you have in mind. What must be changed. I'll look when I have some time.
Right now you can change it to white if you like.
Just read the how to in the "Extra layouts" folder in the rar file. You allso can use anothet clock background.
I'll look at it, but I can't promise anything.
I think that extra icon is not necessary because, if the HD icon isn't led than it means that the channel is SD.
It also won't look nice if the icon is at another place at VFD, because at the row where the icons are isn't enough place for another one.
If it's not HD, then it's an SD and could display exactly where HD displays.
@sat gr
my friend just i think file in addons server is to simple...
i was try change it like your how to in the "Extra layouts" folder but not success
i was add 2 png b_time and b_time1 without delete something
i was add my favorite STB_background_15 renamed to STB_background
restart enigma but not success
my image is Black Hole 2.0.2E
@sat gr
I think you are doing something wrong.
1. Open "Diferent Clock background" folder in "Extra layout"
2. Rename the clock 15 to STB_background
3. Open DCC and and FTP the renamed clock to :/user/share/enigma2/vfd_icons
when you are asked to overwrite, select yes
4. now FTP the other two files from "White background...." folder to: /user/share/enigma2/vfd_icons
select all on overwrite.
No need to restart Enigma, just go on standby and the new layout will be there.
P.S. If you want to try another clock background, first rename clock 15 to STB_background_15.
Select another clock layout and rename to STB_background and FTP ( overwrite ) that file.
@sat gr
i did all that my friend i will try again thanks for your time
