Upgrade and NEW Skins Open Black Hole
I agree. Maybe the satellite used or DVB-T info, but not everything, although it might be useful under rare circumstances...
For instance, sometimes there are channels working with different frequencies or services and one might want to understand which one he had already added to some bouquets. Once, I became crazy to include the best service among the ones possible ;) But, as I said, it's unusual.
And, besides, this happened because of a small limitation OBH has compared to BH, something I've already underlined several times: in BH, if you go through the ALL SERVICES LIST (or through a specific satellite list) and zap, if a services is already included in at least one bouquet, you see a number in the infobar, otherwise you see "- - -". In OBH, instead, you always see "- - -" also for the services included in bouquets.
I am looking for a skin which gives you complete information about sid, video pid as well as audio pid etc on Info bar . I hope someday you would compile such a skin
?????? Pressing twice the OK you have always had what you asked in every skins and, if you set the timeout for the 2nd infobar to "No timeout", you can read these infos in peace and also zap: the 2nd infobar will be always ON.
In these cases (of a skin's update) what do we need to do? Uninstall a skin and then reinstall or just reinstall it to overwrite its old files?
Hi Matrix,
would it be possible to have, also in Waves4 Fire, the SAT and the transponder's info in the skin as in BlackShadow?
Particularly the SAT info would be very useful as while you have the mode ALL CHANNELS and they have the same name in different satellites.
