Upgrade and NEW Skins Open Black Hole
Skins UPDATE OpenBh 5.0.002 (Release)
I started upgrading skins for OpenBh
Download from OpenBh Skins image panel
Pay attention skins for 5.0.002 and Up can only be used on OpenBh 5.0.002 and Up (Release)
So if you are using an older version you have to install and Update image.
Info about skins update for OpenBh 5.x (5.0.002 and Up)
Pay attention only skins marked (5x / up) are for the latest versions of OpenBh.
We are also using a new server
Working just fine with the downloads up here in Scandinavia... :)
Or maybe we are uploading since we are future north to the new server ;) :lol:
I noticed the WEATHER versions are no longer there?
They were yesterday and I have the Waves 4 Fire Weather working well in OBH 5.0.3
Will you put the other options back?
Thanks again for great Skins.
This is not possible because the old WEATHER plugin does not work on Python 3
I don't understand how it worked for you.Not working for me.
Problem with weather plugin.Which plugin did you use?
Did the plugin work for you?
@Matrix10
I uploaded the plugin as per instructions on skin install that you provided with 4.4
I installed it as before and its running fine on my Ultimo 4K with Image OBH 5.0.003 and now 004.
I have a pic of the screen showing it working as it did with 4.4 but I'm unable to upload it here?
@Matrix10
I don't know how you installed it on OpenBH 5.xxx
but to me it fails.
OpenBH 4.4 that's OK
EDIT
new plugin support Obh 5.x download from OpenBh server
I don't understand myself Matrix 10!
It was simply uploaded from the OpenBH Feeds section as with previous versions and it works as it did before??!!
Weird!!!!??
Can you put the Waves 4 Weather up again and I'll try that too if you wish?
Weird!!!!??
No need
if you install this plugin and it works
then the skin will work as well.
If the plugin doesn't work then the skin can't work.
EDIT
All is fixed in plugin to support PY3
Download from OpenBh image server >Obh plugins
A large number of skins have already been updated
download from image server.
(green button>>Yellow>>Addons Feeds Manager>>OpenBh image Skins)
