USB Tuner: AF9035 devices
grabber1
Vu+Duo IPK for AF9035 devices on BH 1.7.0.
Installation instructions:
1. upload the IPKs attached to this post into your /tmp box folder via FTP
2. remove the current A867 driver with
ipkg remove kernel-module-dvb-a867 --force-depends
3. install all the ipks posted here with
ipkg install /tmp/*.ipk
4. connect your device
5. execute these two commands
depmod
depmod.26
6. reboot your box
Great job,work very fine in my vu+ duo.
Many tanks:D
fabrizio432
Great!
Works like a charm for me with Aver Volar Green HD.
Hope they will be packed within the future releases of image.
Bye
foxstam
Little Help Please. I can ftp the files form my mac using cyberduck but i can not terminal (ssh) because i don't know user name and password. I tried root and user as login name and passwd and password as password but nothing. Any suggestion to solve this or reset user name and password?
Thank you in advance!!!
50_lire
The default username is root and the password is empty (no password).
50_lire
thanks for the answer but mine is second hand so i have to find way to erase the previews password (linux method i think)
hmmm, I think the only way (and the fastest ;)) is reflashing with the last image.
I'm not a linux expert, but I think you can't change the root password if you can't log in the system...:oops:
foxstam
Every time when i reflashing i had the same problem with the password until i reflashed B.H 1.7.0 and download BH plugin changerootpassword. And press <null> and the i have ssh access. Thank you very much.
angelofsky1980
BlackHole Driver Specialist
I think you can change very quickly the root password of your box via telnet.
Login into your box and launch passwd program.
gigelai
depmod
depmod.26
6. reboot your box
Mitico :victory:
400 canali DTT sintonizzati !!!!
:thanks:
Per me non e' un problema, e' solo una curiosita' :
secondo voi xche' tra i 400 sintonizzati mancano solo Rai1 Rai2 e Rai3 ?
Ciao
grabber1
Mitico :victory:
:thanks:
Ciao
Su che frequenza li ricevi?Da me sulla frequenza 205.500 non c'è verso di beccarli usando la aver media green af9035.
CONOR
Reference driver: Avermedia AverTV Volar HD (A835)
Driver Name: af9035
Here is a list of possible compatible devices with the mentioned driver. Please test it and report if works or not.
How do I set up the Avermedia AverTV Volar HD (A835) as mine is not finding any channels.
I have it set up to DVBT & the european region.
I'm using BH 1.7.1 & a VU DUO box.
I dont have any other USB devices connected.
Nash
Hi BH, thanks for the new 1.7.2 update. Aver volar Green HD is not OK with 1.7.2 and the new driver 0.3.9, when you put a channel I haven't got signal (S/R) and the TV is black, in 1.7.1 the Aver Volar Green HD is OK =), please if you could fix it in the new image...
Thanks in advance!
