USB Tuner: DIB0700 devices
Hi @angelofsky1980, i have second USB stick Emtec S810 (first one is AF9015) and like i read on the net it is DIB0700 compatibile, but the install can not recognizes it. Is it possible to patch drivers with this device id ?
Adds support for Emtec S810 (1164:2edc device id) dvb-t usb stick to
dib0700. Here is there relevant line from lsusb:
Bus 004 Device 003: ID 1164:2edc YUAN High-Tech Development Co., Ltd
Patch against latest v4l-dvb tree (pulled about half an hour ago).
Thanks
Thanks
This evening I will make some tests.
Hi
The Hauppage Nova T can receive HD channels or is necessary the Nova T-HD?
Thanks
Read my new thread :)
I tried a Hauppauge Nova-T Stick (dib0700), 2040:7070. On VU Duo it was detected and installed fine. On VU Solo, the detection was failing but driver was loaded successfully. It seems that the problem was that the driver needed some more time to load in VU Solo. I edited delitedtt.sh and addes 5 seconds delay before loading usbtuner and then it worked fine.
Vu Solo has fewer usb dvb-t options (7 options, vu duo has 9). Why is this?
Thamls for your report about loading time from your boxes.
I've found the same "bug" with AF9015 driver but was the only driver with this issue.
I have added a delay time to all drivers and I upgrade all packages on the server during this weekend.
For the quantity of items, the Duo and Solo box have their dedicated panels and I manage the two entity separately. It's possible that a driver is published only for Duo or only for Solo but if you need one of missing ones, write to me or post in the board and I will add the missing item ASAP :)
Leadtek WinFast DTV Dongle H NOT working :(
Could you please post some debug infos about your problem like output of these commands:
dmesg
cat /proc/bus/usb/devices
/usr/bin/usbtuner -V
All commands have to be issued to the box into a telnet session on your STB with the USB DVB device connected.
Thanks!
dmesg
Thanks!
[AUD]: AUDIO_SET_MUTE 0
[LCD]:bm730_dbox_lcd_write_data
[LCD]:vfd reply success
FE tune
[AUD]: AUDIO_SET_BYPASS_MODE 1
[AUD]: proc_get_ac3 0 bcm7335->audio_passthrough_spdif : 0
[AUD]: AUDIO_PAUSE 1
[AUD]: AUDIO_PLAY 1 decoder start : 0
[AUD]: bcm7335->audio_dec_ss.codec 1
[VID]: VIDEO_SET_STREAMTYPE 0
[VID]: VIDEO_FREEZE 1 0
[VID]: VIDEO_PLAY 1 2 2
[VID]: VIDEO_SLOWMOTION 0 1
[VID]: VIDEO_FAST_FORWARD 0 1
[VID]: VIDEO_CONTINUE 1 1
[AUD]: AUDIO_CONTINUE 1 1 audio pid_hndl : 0xc09d9b5c
[AUD]: setting mute : 0
[VID]: VIDEO_STOP 1 1
[AUD]: AUDIO_STOP 1
[AUD]: AUDIO_CONTINUE 1 0 audio pid_hndl : 0x0
[AUD]: AUDIO_CONTINUE:bcm7335->audio_pid_hndl is null 0 0
FE tune
[LCD]:bm730_dbox_lcd_write_read_data len: 8
[LCD]:rtc data received 4
[AUD]: AUDIO_STOP 1
[AUD]: AUDIO_CONTINUE 1 1 audio pid_hndl : 0xc09d9afc
[AUD]: AUDIO_STOP 1
FE tune
[AUD]: AUDIO_STOP 1
[DFP]:scart_select_tvout aTVOutType = 1
bcm7335: hotplug_callback():
Hotplug - status.connected 0
Hotplug - Disconnecting HDMI from display
Hotplug - status.connected 1
Hotplug - connecting HDMI to display 0x0
dib0700: Unknown remote controller key: 001e 1d e2
dib0700: Unknown remote controller key: 0002 31 ce
[DFP]:scart_select_tvout aTVOutType = 2
FE tune
Hotplug - connecting HDMI to display 0xf
[DFP]:dbox_fp_open
[DFP]:dbox_fp_ioctl cmd : 0
[DFP]: unknown cmd 0x0000
[DFP]:dbox_fp_release
root@vusolo:~# cat /proc/bus/usb/devices
T: Bus=04 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=12 MxCh= 1
B: Alloc= 0/900 us ( 0%), #Int= 0, #Iso= 0
D: Ver= 1.10 Cls=09(hub ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=0000 ProdID=0000 Rev= 2.06
S: Manufacturer=Linux 2.6.18-7.3 ohci_hcd
S: Product=BRCM OHCI
S: SerialNumber=ohci-brcm
C:* #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr= 0mA
I: If#= 0 Alt= 0 #EPs= 1 Cls=09(hub ) Sub=00 Prot=00 Driver=hub
E: Ad=81(I) Atr=03(Int.) MxPS= 2 Ivl=255ms
T: Bus=03 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=12 MxCh= 1
T: Bus=02 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=480 MxCh= 1
B: Alloc= 0/800 us ( 0%), #Int= 0, #Iso= 0
D: Ver= 2.00 Cls=09(hub ) Sub=00 Prot=01 MxPS=64 #Cfgs= 1
S: Manufacturer=Linux 2.6.18-7.3 ehci_hcd
S: Product=BRCM EHCI
S: SerialNumber=ehci-brcm
E: Ad=81(I) Atr=03(Int.) MxPS= 2 Ivl=256ms
T: Bus=01 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=480 MxCh= 1
T: Bus=01 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 2 Spd=480 MxCh= 0
D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=0413 ProdID=60f6 Rev= 0.01
S: Manufacturer=Leadtek
S: Product=DTV Dongle H
S: SerialNumber=1
C:* #Ifs= 1 Cfg#= 1 Atr=a0 MxPwr=500mA
I: If#= 0 Alt= 0 #EPs= 4 Cls=ff(vend.) Sub=00 Prot=00 Driver=dvb_usb_dib0700
E: Ad=01(O) Atr=02(Bulk) MxPS= 512 Ivl=125us
E: Ad=81(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=82(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=83(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
root@vusolo:~# /usr/bin/usbtuner -V
UsbTuner v0.2.6
root@vusolo:~#
Could you please post the output of this command?
ls -l /dev/dvb
Thanks!
Seems that your USB DVB device is correctly detected.
ls -l /dev/dvb
Thanks!
OpenEmbedded Linux vusolo
root@vusolo:~# ls -l /dev/dvb
drwxr-xr-x 2 root root 760 Dec 14 07:10 adapter0
drwxr-xr-x 2 root root 120 Dec 14 07:09 adapter1
VU+ Solo sees the tuner Leadtek, I can change the settings, but the channel scan does not give any results on my PC tuner is working properly
FYI
USB DVB-T Hauppauge wintv nova-td DUAL TUNER stick works perfectly on BlackHole-1.6-bm750 with S/N bar too.
Fpippo
Reference driver: Hauppauge WinTV Nova-T Stick
Driver Name: dib0700
Here is a list of possible compatible devices with the mentioned driver. Please test it and report if works or not.
I tested eyetv DTT Deluxe with dib0700. :(
Please support this device too.
How do I REMOVE the driver???
thanks,
a19a
I have a problems on uno with stopping picture. After some time hard zapping (changing to channels on different frequencies is the main problem as i notice) a have a black screen and i have to restart box to get picture back.
I have this problem on 4 different stick:
Chinese AF9015
Chinese Afatech it9135
Gigabyte U80000-RH (dib700)
Pinacle Nano (dib 700)
here is a log of this last one i dont know can it help you
Sony Play TV working (mostly), in the last few images, since last November. I'm on 1.7.5 now.
Sometimes, the video and audio go haywire, into a short loop, or just freezes, then blank.
Is there any command from telnet to help you debug this? Something I could run to see what the problem is?
Same problem As Zupy-- 1.7.6 and DIB0700 i have picture when im restarting the Vu DUO, after chanell chnage: SID not found in PAT message, and nothing..
not even the previously watched chanell good--- signal is good, C mark is blue..
How can we update the drivers-- this stick worked with 173 image, when the drivers could found under the blue button... any solution?
