Vu+ BH Team Only 1 Question i have please ! Thanks a lot !
fot vti for example easy python fix is .......... /usr/lib/enigma2/python/Components/Converter/FrontendInfo.py or pyo
elif self.type == self.SNR:
percent = self.source.snr
elif self.type == self.SNRdB:
if self.source.snr_db is not None:
return '%3.02f dB' % (self.source.snr_db / 100.0)
if self.source.snr is not None:
return "%3.1f dB" % (((self.source.snr / (65536.0 / 100.0)) * 0.1800) - 1.0000)
in pli 7.3 sdgr 8 and vix or OBH they have done it in frontend.cpp //// better way but dificault
frontend.cpp needs linux knowlege
is something like that..............
else if (!strcmp(m_description, "DVB-S2 NIM(45208 FBC)")
|| !strcmp(m_description, "DVB-S2 NIM(45308 FBC)")
|| !strcmp(m_description, "DVB-S2X NIM(45308X FBC)")
ret = (int)((((double(snr) / (65535.0 / 100.0)) * 0.1950) - 1.0000) * 100);
All thease not in BH images :(
Yes Rodrigues ....also in terestrial shows in db(((when the patch is done from frontend.cpp(linux work) and not in easy python file . py / pyo decompile
even in vu+ with db frontend.cpp fix calc not real of cource..
We need drivers from Vu+ ........also in blindscan for dvb s2x tuners
Also in Zero4k with frontend.cpp fix which is dificault or python fix not in Bh but all others images ....show db fake calc
also i need if Matrix agree a fix python or anything else..to show db in bh 3.0.9 for example
In pm
Tkh a lot!!
@lex7791,
Abt SNR dB fix
I really do not know ,because I am not an image coder.
I do almost exclusively skins and image testing.
I'm not sure the BH coder wants to change the VU + base coding.
In principle, these things should be fixed by VU + maybe you can send them,which they might include in the update.
You know there are a lot of things that could be changed but then we would go beyond the VU + coding base.
That's why we created the Open Black Hole image.
But if you make a fix I can ask the coder if he wants it to change.
Dear p.rodrigues a question for you ... my friend
which is the signal name app in your photo and in what type of os --phone--android or iphone ?
i have only android...
