VU+ Duo 4K
1.Yes
2.NO
Thank you very match Matrix. I will request your help later on for the activation for transcoding. This possibility is really important for me. Unfortunately, in the receiver I have right now (VU+ duo HD) I didn't manage to make it.
I´m just becoming to not understand nothing!
This is a thread for Duo4K Vuplus Stb, although you are referring on your posts, to a Duo2 4K, and then, from your post #82 -->
, you are referring to a Duo HD ( Vuplus Duo STB - original one, i think? ... ), and further more for lastest, on a thread for a Vuplus Duo4K, you are talking about a Sony TV!
This is insane, isn´t is?
This is a thread for Duo4K Vuplus Stb, although you are referring on your posts, to a Duo2 4K, and then, from your post #82 --> , you are referring to a Duo HD ( Vuplus Duo STB - original one, i think? ... ), and further more for lastest, on a thread for a Vuplus Duo4K, you are talking about a Sony TV!
nunigaia I apologize for the disturbance I caused to you. The buyer I bought is vu + duo 4K. I was wrong in the description, I wrote it, I think.
My question was about the comparison of the two tuners, the DVB S2X, and the TV tuner I'm using now. I did not know that was wrong.
I apologize and old ..
