Duo / DuoLE Vu-duo is Dead
Many duos have this problem now so how does one solve it after the fix ? Use it without HDD ? OR COOL IT DOWN MORE
hi
when i turn off my Vu+ Due from behind and turn it on there is no problem, but when leave it off for about 1 hour and more it takes 4-15 minutes for red led to turn off and my vu+ says starting.
any suggestions?
I've got the same problem like sarab_h for few weeks. I can not start the box from remote, just to turn of and on the power. I thought it was my image(BH 1.7.0) corrupted so, I've downloaded B.H. 1.7.9, i put it on the stick and flashed the vu+uno. It says remove the stick and restart. I've did it and the it appeared the red led and nothing more. What did i do wrong? I have tried with vu utility and it stops at 20 percent. I tried with 4 different usb sticks without succsess. Should i try to change the capacitor? I am in the same situation like all the people above?
my clon dvb s2 hd pvr twin slm vu + duo have my device usb device software from the software threw a red light is shut when I had to Start Start will still remain, but are running out of 232 to 40 utille vu when it comes to software, threw me five stages versed eror help me in this regard is I would appreciate if you have any offers or service information, please send it
warning
serious violation of the forum rules
There is no support for the clone.
Another post like this and you will be banned from the forum.
Read forum Rules
Use an 2,5" HDD with adaptor for 3,5" housing and let the fan on in standby. Box will be more cool.
Also check fan functionality very often, because when the fan is broken, there is no warning about its fault.
Unfortunately the electrical schema for the VU+Uno is not the same as VUDuo. There is already a capacitor with this value:330uF 50V but is not located where C807 is on the DUO. I don't know what to do.
I would like to warn you. It's absolutely not recommended to exchange any components of faulty PSU (power switching unit). You are risking your life, especially if you are not an expert. When the PSU is faulty it's recommended to change it to avoid other damages. I agree, that in 99% of cases the problem is a dry output capacitor, but 1% not. So be very carrefull!
Is the solution the same for Solo flashed with wrong bootloader, change C807? It has the same sympthom as the once in this thread, the red led and no boot.
ok, guys. i gave the same problem: my vu+ duo hand on "starting..."
this is my hyperterminal log:
resolve: -> /usr/share/enigma2/defaults/
resolve: resolve ${datadir}/enigma2/dealer
resolve: -> /usr/share/enigma2/dealer
resolve: resolve ${datadir}/meta
resolve: -> /usr/share/meta
resolve: resolve ${datadir}/enigma2/defaults/
enumerating block devices...
found block device 'loop0': blacklisted
found block device 'loop1': blacklisted
found block device 'loop2': blacklisted
found block device 'loop3': blacklisted
found block device 'loop4': blacklisted
found block device 'loop5': blacklisted
found block device 'loop6': blacklisted
found block device 'loop7': blacklisted
found block device 'mtdblock0': blacklisted
found block device 'mtdblock1': blacklisted
found block device 'mtdblock2': blacklisted
found block device 'mtdblock3': blacklisted
found block device 'mtdblock4': blacklisted
found block device 'mtdblock5': blacklisted
found block device 'mtdblock6': blacklisted
found block device 'sda': ok, removable=True, cdrom=False, partitions=['sda1']
found block device 'sda1': error querying properties
not loading user skin:  [Errno 2] No such file or directory: '/etc/enigma2/skin_user.xml'
main thread is non-idle! display spinner!
bcmemac: eth0 NIC Link is Up 100 Mbps Full Duplex
menu_mainmenu
Reading satellites.xml
resolve: resolve ${datadir}/enigma2/unicable.xml
resolve: -> /usr/share/enigma2/unicable.xml
removing internal link on frontend id 1
sec config cleared
setSlotInfo for dvb frontend 0 to slotid 0, descr BCM7335 DVB-S2 NIM (internal), need rotorworkaround No, enabled No, DVB-S2 Yes
setSlotInfo for dvb frontend 1 to slotid 1, descr BCM7335 DVB-S2 NIM (internal), need rotorworkaround No, enabled No, DVB-S2 Yes
slot: 0 configmode: nothing
slot: 1 configmode: nothing
sec config completed
Preferred tag editor set to  None
resolve: resolve ${datadir}/enigma2/setup.xml
resolve: -> /usr/share/enigma2/setup.xml
resolve: resolve ${sysconfdir}/enigma2/
resolve: -> /etc/enigma2/
loading bouquet... /etc/enigma2/bouquets.tv
loading bouquet... /etc/enigma2/userbouquet.favourites.tv
213 entries in Bouquet userbouquet.favourites.tv
1 entries in Bouquet bouquets.tv
loading bouquet... /etc/enigma2/bouquets.radio
loading bouquet... /etc/enigma2/userbouquet.favourites.radio
0 entries in Bouquet userbouquet.favourites.radio
1 entries in Bouquet bouquets.radio
[eDVBLocalTimeHandler] enable sync local time with transponder time!
add dreampackage scanner plugin
added
Installing image defaults
Reading .info file /usr/share/enigma2/defaults/Dream/dm8000.info
prerequisites: {u'bcastsystem': ['DVB-S']}
prerequisites: {u'bcastsystem': ['DVB-C']}
prerequisites: {u'bcastsystem': ['DVB-T']}
Reading .info file /usr/share/enigma2/defaults/Dream/dm800.info
Reading .info file /usr/share/enigma2/defaults/Dream/dm7025.info
Reading .info file /usr/share/enigma2/defaults/Dream/dm500hd.info
Reading .info file /usr/share/enigma2/defaults/Dream/dm7020hd.info
Reading .info file /usr/share/enigma2/defaults/Dream/dm800se.info
prerequisites: {u'hardware': ['dm8000']}
prerequisites: {u'hardware': ['dm800']}
prerequisites: {u'hardware': ['dm7025']}
prerequisites: {u'hardware': ['dm500hd']}
prerequisites: {u'hardware': ['dm7020hd']}
prerequisites: {u'hardware': ['dm800se']}
self.packageslist: [({'prerequisites': {u'hardware': ['dm8000']}, 'attributes': {u'config': [{'directory': '/usr/share/enigma2/defaults/Dream/', 'name': 'settings.8000'}], u'favourites': [{'directory': '/usr/share/enigma2/defaults/Dream/', 'name': 'bouquets.tv'}, {'directory': '/usr/share/enigma2/defaults/Dream/hdbouquets/', 'name': 'userbouquet.favourites.tv'}], 'filestype': 'directories', 'name': 'Dream Multimedia Default', 'author': 'Dream Multimedia GmbH'}}, '/usr/share/enigma2/defaults/Dream/dm8000.info')]
installing package with index 0 and name Dream Multimedia Default
currentAttributeIndex: 0
installing skin with index 0
currentAttributeIndex: 1
installing config with index 0
merging config: /usr/share/enigma2/defaults/Dream/  -  settings.8000
installing config with index 1
currentAttributeIndex: 2
installing favourites with index 0
installing favourites: /usr/share/enigma2/defaults/Dream/  -  bouquets.tv
installing favourites with index 1
installing favourites: /usr/share/enigma2/defaults/Dream/hdbouquets/  -  userbouquet.favourites.tv
installing favourites with index 2
currentAttributeIndex: 3
currentAttributeIndex: 4
installing services with index 0
end of package reached
set status to DONE
installing done!
[FONT] adding font /usr/share/fonts/nmsbd.ttf...OK (Display)
[FONT] adding font /usr/share/fonts/lcd.ttf...OK (LCD)
[FONT] adding font /usr/share/fonts/ae_AlMateen.ttf...OK (Replacement)
[FONT] adding font /usr/share/fonts/tuxtxt.ttf...OK (Console)
[FONT] adding font /usr/share/fonts/nmsbd.ttf...OK (Arial)
[FONT] adding font /usr/share/enigma2/Vu_HD_Series/fonts/digi.ttf...OK (DIGI)
[FONT] adding font /usr/share/enigma2/Vu_HD_Series/fonts/nmsbd2.ttf...OK (Regular)
[FONT] adding font /usr/share/enigma2/Vu_HD_Series/fonts/arial.ttf...OK (RegularLight)
[iInputDevices] getInputDevices  <ERROR: ioctl(EVIOCGNAME): [Errno 25] Inappropriate ioctl for device >
[iInputDevices] getInputDevices  <ERROR: ioctl(EVIOCGNAME): [Errno 25] CPU 0 Unable to handle kernel paging request at virtual address 00000028, epc == c0721f4c, ra == c0722604
Inappropriate ioOops[#1]:
Cpu 0
$ 0  : 00000000 30008700 c0721f4c 00000000
$ 4  : 00000000 30008701 000000b8 00000000
$ 8  : 00000018 802cb078 00000000 00000000
$12  : 7624ee10 77392020 00000000 005d0000
$16  : 00000002 86d11e18 00000002 c07225dc
$20  : c0722618 c0722670 76f64d28 01022a08
$24  : 00000000 c074b510
$28  : 86d10000 86d11de8 010870c0 c0722604
Hi    : 00000000
Lo    : 00000198
epc  : c0721f4c NEXUS_Gpio_Close_impl+0x0/0x88 [dvb_bcm7335]
    Tainted: P
ra    : c0722604 NEXUS_Gpio_Close+0x28/0x3c [dvb_bcm7335]
Status: 30008703    KERNEL EXL IE
Cause : 00800008
BadVA : 00000028
PrId  : 0002a044 (Brcm4380)
Modules linked in: brcmfb dvb_bcm7335(P) procmk
Process enigma2 (pid: 759, threadinfo=86d10000, task=86cd0490, tls=77cec490)
Stack : 0000000d 86d11e24 00000000 00000022 00000000 86d11e18 00000002 c07071c4
        00000001 00000028 0ee6d0f9 c0706a30 00000002 00000001 00000000 00000000
        00000000 00000000 00000004 c0b09ecc 0055a6c4 86d11f10 01086f80 00e1f406
        76f64d28 c07045bc 00000100 800441e8 80650000 806d0000 886b1680 86d36980
        0055a6c4 8011c9f8 195c0109 0000000b 86caa010 88c1cee0 0055a6c4 00000004
Call Trace:
[<c0721f4c>] NEXUS_Gpio_Close_impl+0x0/0x88 [dvb_bcm7335]
[<c0722604>] NEXUS_Gpio_Close+0x28/0x3c [dvb_bcm7335]
[<c07071c4>] max9597_enable_output+0x98/0x1fc [dvb_bcm7335]
[<c07045bc>] proc_write_color_format+0x10c/0x1a8 [dvb_bcm7335]
[<8011c9f8>] proc_file_write+0x78/0xd0
[<80115be4>] proc_reg_write+0x7c/0xc4
[<800bf6c4>] vfs_write+0xa4/0x184
[<800bfa00>] sys_write+0x4c/0x90
[<8000e3fc>] stack_done+0x20/0x40
Code: 8fb00010  03e00008  27bd0020 <8c850028> 27bdffe8  afb00010  afbf0014  10a00007  00808021
ctl for device >---[ end trace c362f538b4a4f46a ]---
look @ the end of the log.... i don't like the last 10 rows...
thaks 4 support!
best regards!
solved!
problem when starting the box with a computer monit attached by hdmi!!!!!
let the box start without hdmi connection, ant everything wi'll be fine!
thanks 4 support and best regards!
count me to the list with red light of death
i will replace the cap with a new but searching on net i found that some guys replace it with 220mf/16v, matrix said 330mf/16v and some 330mf/25v
as i am not a electronic guy i am a little confused
which is the better solution ? i understand that 330mf/16v maybe is better but a little explain for the differnce in 16v vs 25v please
and thanks to all for this thread
