Announcements Vu+ PlayerHD for iPhone & iPad
I can confirm this app does seem to work fine for remote streaming from a Duo2 provided:
(1) The home static IP address is known or Dynamic DNS is configured.
(3) You have plenty of upstream bandwidth (2Mbps+) at home and a very good Wifi or 4G Cell signal remotely.
(4) You have opened your home firewall to forwarding ports 80, 8001 and 8002 to your box.
The latest OpenWebif streaming link also works well by opening Quicktime player on my iPad.
Hello, I have a solo2 with one lnb cable in tuner A and tuner B "equal to tuner A". The issue is that I cannot find the way to watch different channels in Tablet and TV (multituner in Vu Player App is on...)
Can someone help me? thanks a lot folks!
You need a true two LNB installation to see two different channels.
your configuration may work if your lnb was an Unicable (SCR) and for each input assign a different channel scr;)
Hi thanks so much for your answers. Sorry Im quite newbie on this. I live in a community neighbourhood and we have all an antenne so basically i know that i have an only lnb comming and not much more. Can you help me to understand what i should to manage to have both lnb working?
When I bought the Solo2 I thought it was just a matter of connecting the cable to tunerA and switching tuner B equal to tuner A.
Just set Tuner B to 'loop through'
Hi, I've got 2 cables now, one for each tuner. Now I can see two different chanels. BUT... if I have a channel in the Tablet and change the channel in the TV everything goes well, but if it is in the Tablet where I change the channel, it also changes it in the TV, any solution for that? Thanks in advance!
Your tuners must be configured with equal configuration BUT not use "Equal to tuner <n>". With little setup you should solve your problems.
Hi,
It don't work for me, since I've installed the Vu+ player HD on my IPad! I always get a message "impossible to connect, it's not a VuPlus product". It works fine with the old app!
The app can identify the box but the light don't turn to green...
Need help ;-)
Hi,
Need help ;-)
Try to set it by manual configuration.
Very strange...
Try to uninstall the app and then install it again.
I have done it a couple times and still don't work...
Blackhole 2.0.3 (didn't do the update because everything else works well and you know "never touch a good running system :-))
Anyway I don't think that the update solves the problem, do you?!
Openwebif 0.1.2
Ipad ios 8.1.3
Blackhole 2.0.3 (didn't do the update because everything else works well and you know "never touch a good running system :))
Openwebif 0.1.2
Ipad ios 8.1.3
You are using an outdated image, I advice you to upgrade to the last BH image ;)
Thanks for the advice! Like I said, everything else works well and the l'astuce time I've done an upgrade, I had some problems with plugins! If it would solve the problem with the Vu+ player HD, I would do it...
