VU+ Ultimo WLAN
I have vu+ duo2.. my builtin wifi was connected 100% in Black Hole Image, but the other Images (such as VTi, OpenVix..) weren't, Why?! Maybe missing drivers or something like this regarding programming system..
HI !
Well I had lots of problems with connecting my Duo2 with WiFi...The Problem is that BlackHole Image does not like !§$%& signs in the password.
I've changed my Wifi password into a passphrase with only LETTERS and NUMBERS and it connects without any problem.
OK Who can tell how to install the OpenATV Wifi Drivers into the BlackHole Image ? OPENATV Had no problems with my old password, or maybe there is some other workaround ?
HI !
Drivers? You are wrong. There are more components involving into wifi connections and maintenance .... BH uses the codebase from VuPlus plus some drivers and implementations made internally from the Team. Other images uses other codebase different from official VuPlus (except box drivers components).
I don't see security problems to have a wifi password with sufficient length (8-10 chars) in alfanumeric and uppercase/lowercase combination using WPA/WPA2 encryption.
