Vu+ Zero tested for you!
Can anyone let me know if we can record a program to an external USB HD with the VU+ Zero?
Yes. We can!
Mount it as /media/hdd
on the root of your hdd upon mounted create a directory named <movie> !
Now you should be able to record on it!
I just worked Zero device front lights
LAN port works but I have no video cable.
USB port does not work so I could give a new program Bhhsh
Black hHOL image was installed on Zero.
Has talked and worked first PLI image
Black Hole and got the latest version of the image after it happened.
It's not clear what happen.
The first phrase is quite strange: LAN works but no video cable .... it's impossible you haven't the HDMI cable... do you mean "from video output no picture appear"?
The second phrase: USB port does not work: have you tried both porrts without other devices connected?
I've reflashed my Zero hunderds of times and I've had no problems .... I suggest to ask warranty replacement from your seller.
Good Job ! Zero is really good solution for those which dont need many functions but they like to have good quality/performance STB. I purchase one last year and since now work perfect ! Even my one work 24h because we always turn off the TV and forget about ZERO :D I had some experiances with DM800HD But ZERO it`s a way better ! And the RC it`s a masterpiece !
Ooo only one thing , The Power LED (White one) on front panel dimm not enough when you put him to sleep .So often I dont know it`s on or off .This is one issue which I notice. Or maybe it`s possible to change the settings ? Anyone have any idea ?
Just i bought a Vu+ zero for other room to my parents . i set all channel , satelit from vu+ solo se . but i found a bug or a defect to tuner.
I set to simple diseqc A/B/C/D.
Whitout cable to tuner show a signal on DVB-S2 trasnsponder AGC 86% and SNR 59%. On DVB-S show diferent AGC 86,91% and glimmer SNR 0-20%.
I do not have a satellite dish to test before sending it to parents.
Test original image(vu plus code) and BH 3.0.3.
Other Vu+ ZERO look the same or i got one defect?
Cześć mam VU+ zero od 3 lat śmiga aż miło wgywalem Black hole a że 3-4 razy i go nie zbrikowalem więc tutaj nie ma problemu. U mnie chodzi 24h bo tylko wyłączam telewizor na noc :D świetny sprzęt pod wyjście kompozytowe mam podłączony telewizor w sypialni ! Pendrive służy jako HDD i świetnie się sprawdza !
Wysłane z mojego SM-G950F przy użyciu Tapatalka
