Vuplus Zero - bootloader Upgrade V 1.04 24/02/2015
Valk
Hey guys. Can any1 tell where can I get support for my Zero? BL update didn't help. Can't get my lan and wlan to work properly.
Tried all kind of images and resets.
Valk
Try first with DHCP on.
After that you can modify by turn DHCP off and set the DNS1 and DNS2.
For DNS's use the google DNS.
DNS1: 8.8.8.8
DNS2: 8.8.4.4
Ofc I tried every setting possible. If I didn't tried wlan I would be sure that the problem is with my home lan. But wifi is not working either.
iman_miri
If all works good ... and if you have no fails of internet using ethernet connection, you don´t need upgrade the CFE!
The information " official " from vuplus is clear!
i have problem with wifi use and any 1 or 2 hours disconect and crash and i should restated i need to update or not> ? only with wifi but with cable no i donnt have problem my image is updateed
Moderator
Why? The first post is clear! ;)
1. Ethernet lan connections is not Wifi.
2. Your STB has not Wifi buit-in.
§. Only if you have trouble with lan connections.
nunigia
