Vuplus Zero - bootloader Upgrade V 1.04 24/02/2015
Hey guys. Can any1 tell where can I get support for my Zero? BL update didn't help. Can't get my lan and wlan to work properly.
Tried all kind of images and resets.
Try first with DHCP on.
After that you can modify by turn DHCP off and set the DNS1 and DNS2.
For DNS's use the google DNS.
DNS1: 8.8.8.8
DNS2: 8.8.4.4
Ofc I tried every setting possible. If I didn't tried wlan I would be sure that the problem is with my home lan. But wifi is not working either.
If all works good ... and if you have no fails of internet using ethernet connection, you don´t need upgrade the CFE!
The information " official " from vuplus is clear!
i have problem with wifi use and any 1 or 2 hours disconect and crash and i should restated i need to update or not> ? only with wifi but with cable no i donnt have problem my image is updateed
Why? The first post is clear! ;)
1. Ethernet lan connections is not Wifi.
2. Your STB has not Wifi buit-in.
§. Only if you have trouble with lan connections.
nunigia
Hi nunigaia
I got two vu plus zero both are crashed.
i try your guide but nu lucky ,
when you saying Unzip the vuplus_zero_cfev1.04.zip to USB stick.(There should be /vuplus/zero/cfe_cfe_auto.bin)
sgould be /vuplus/zero/cfe_cfe_auto.bin rename the file or just extraxt and put it on usb after extraxt is just vuplus,
please can you explain i use to flash any image but this wont stat flashing the bootloader ..
please let me know..
Reagrds
