Which Vu+ do you have?
  • Total voters
    1,319
Vu+Solo2. Almost two years, it´s just a piece of shitt because of driver problems. Can be used only with a cheap or falke TVs, without automatic resolution plugin installed. If you need a good picture and you have a good TV unit, stay away from Vu+.
AHAHAHAHAHAHHAHAHAHAHAHAH are you crazy?
Of course Cheap imitated once , like what you may have :wallbash:!
Will never come close to a genuine VU+....:)!
It is an original item, of course :) Otherwise I wouldn´t write here about the problem and wait almost a year for any solution. Unfortunately all the Vu+ models seems to be a cheap imitation of an old linux box. Now it´s running on the ceiling with an old TV, without autoresolution plugin, providing poor fake picture on any SD resolution channel. My 55F8000 is now running with a real linux box :) Sorry about Vu and all its´ team :(
No, I just want to have a good picture on any HD and SD channel on my TV. The upscaling should be made from my TV but not from the box. Vu+ can not provide this because of driver problems and missing OSD by using of the autoresolution plugin. So Vu+ is designed to be used with a cheap small TVs :) I´m not crasy to use any of this with my 55F8000 :)
Looks like you to excited with your Samsung TV that's why you putting down Vu+ and that is opinions as I have the same opinion as "rubish" but this time not for vu+ but for any Samsung device and I know is my opinion!!
Sent from my D5803 using Tapatalk
It's funny .... I've the UHD TV in my signature and with ALL VU+ boxes the image is very good in any resolution (SD, HD, UHD).....
Do you think I´ve tested only on this 55F8000 samsung ;) ? It´s not so easy to me to say "A Piece Of Shitt" for a box, I paid 350 euro :(. There was enough play and tests in the last year to earn a quality picture. As I throw it on the ceiling, the problem is solved:notworthy:. Now I have that I needed, thanks God.
