Which Vu+ do you have?
  • Total voters
    1,319
AH! Non era "se quale" ma il se era SE unito a 4K. Quindi era 4KSE... Evviva. La punteggiatura aiuterebbe moltissimo per capire il significato di una frase ;) E la punteggiatura si può aggiungere anche a una traduzione automatica, per aiutare chi legge.
Was it a question? Or an exclamation? Did you mean: "I cannot see the VU+ DUO 4K SE in the list above!!!".
But the exclamation is not needed, because Duo4K and Duo4KSE have the same HW and they differ only for the clock speed.
So, you can surely choose the option Duo4K.
Maybe some @admin would change that line as:
Duo4K/Duo4K SE.
Duo4K/Duo4K SE.
I see you understood this question. I did not know that speed is the only difference. You are right, for clarity, it would be good to change this to Duo4K/Duo4K SE
Thanks
