sempre molto gentile.
Hi,
I am trying to get my picons to work on the lcd display.
It keeps coming up as blank.
I am using Open Blackhole 0.1 on a Vu+ Duo2.
Any ideas?
Thanks
Hi,
I have used your file.
My LCD changes about 10 times but there is no picon displayed on any of them.
Regards
Hi,
My picons are in
/media/usb/picon
These are snp picons.
My picon cache path is
/usr/share/enigma2/picon
still no luck in getting the picon on the lcd display but they do work on skin image.
regards
Hi yes my usb is mapped as /media/usb/
So if my picons are in /media/usb/picon/
Then the cache will be
/media/usb/picon/piconcache/
or
/media/usb/piconcache/
Regards
sorry to ask, how to copy this file into etc/enigma2 folder.Firstly, Many thanks to Evo for uploading his LCDconfig.
This may help those having some issues...
1. Copy the file into etc/enigma2 folder. Ideally reboot enigma.
2. LCD4Linux plug-in, ensure LCD4Linux is set to ON and that LCD display is slso set to ON.
3. Whilst in LCD4Linux plugin, press the menu button on your remote and select reload config.
The third step should then see the LCD spring to life. No need to reflash etc etc
Hope that helps.
Thanks
ES
thanks
Great! Works well! Only the information continuous rotation disturbs a bit. Can I stop the rotation on random stage? Can I change the information stage by hand?
Yes ... If you are using my Lcd4config files, i've setted it up to change the possible 9 Lcd's screens every 5 seconds. With your browser you can acess the Lcd4config and set it up as you desire. Or via the plugins browser, drop down until you find Lcd4Linux plugin setup, open it and set it too.
Hi nunigaia
Probably i have played to much with lcd4linux and now the VDf screen ( not the color one of my duo2) show during normal programs only the top of the picon and in stabye ony the top of time.
What can i do?
I tried to change with lcd4linux config files but nothing changes...
Many thanks
Hall![]()
killall -9 enigma2
