Vytenis P.
There was also to my duo2 - uploaded from backup working /etc/enigma2/lcd4config, completely switched off STB with back switch and later switched on. After boot, everything went OK. Try it
Have you done any backup of your settings (not a full image)? If yes, you can extract with any archiver (e.g. 7-Zip) from backup's /etc/enigma2 folder file cd4config. This file you must to copy to STB's /etc/enigma2 folder with any ftp client. How to transfer you can find in this guide. Or alternatively you can find cd4config in this forum (but it must be for your STB model, because other configurations may be incompatible) and upload it in accordance with earlyer guide...but i donnot understand what am i doing with...
Please write intelligibly, what do you want - picons, streaming to LCD, or something else? We don't have extrasensoric crystal ballsI'm looking for shutter tv only are there any files for shutter tv please
no I'm looking for a shutter tv file so the tv soows up on the lcd
Hi
I have a problem with light vfd panel. name channel is very blurry. I review & ready most topic for regards but not see case that resolve my problem. Please help. BH 3.0.2F
SorryTake a look at your AV Settings - You can adjust the brightness of yor LCD Display ... and turn it off ... if you adjust all to left.
Sorry
My problem with light vfd panel.
Light vfd panel is very blurry. Tanks
Sorry<Menu>; <Setup>; <System>; <Display Setup>
Bright your LCD .... by using the right/left arrow key.
How to help you, if you do not even want to try what offered. Like nunigaia wrote <Menu>; <Setup>; <System>; <Display Setup> is exactly for your VFD display.Sorry
No lcd ; I said vfd panel on stb.
I'm not problem with light & bright TV. I ready all topic but not answer anyone for resolve this problem.
Thanks
Sorry
Thanks
hiThe steps i said is for VFD ... Is the only way to bright it on and turn it more visible.
I have referred in my answer post #475 LCD ... but this settings is for VFD tune up, and is the only way.
