THANKS , Veri, Veri GOOD !!!
Go into the Lcd4Linux plugin, in the green panel, and scroll through the pages until you find the Tuners display option, then move them where you need them and save afterwards.Hi,
I am using the LCD4config from the very 1st post on this thread.
Problem is the Tuner icons A,B and C are in the middle of the Picon.
How do I move these?
Thanks in advance.
i ment the lcd screen
I can't select it . when I select load default nothing happens. It is not selectedIf you mean restore the defaults in L4L, launch the plugin, press MENU on the remote, then Load default.
opkg install --force-reinstall enigma2-plugin-extensions-lcd4linux
killall -9 enigma2
thanks it worksRun this commands by telnet ( one at once ):
Code:opkg install --force-reinstall enigma2-plugin-extensions-lcd4linux killall -9 enigma2
This will bring Lcd4config default ( BlackHole 3.0.3 image ).
nunigia
thanks it works
I can't believe I've been through all the pages and can't see this question asked.
On the vfd screen there is a flashing symbol. Any idea what it is and how to remove it?
Thanks.
Is it the right place to ask, why weather (MSN) for my city (Kavala, Greece) shows also the weather of yesterday? 1st day left is yeasterday, 2nd is today and then the 3 next days.
It works great otherwise!
I use BH 3.0.3.G
Thank you!
