I've forgotten how I managed to reduce by half the size of the clock in the lcd standby display on my duo2.
Can anyone remind me?
I assume you wish to change the size of display in your LCD scrreen. Many posts are published here. I can ouline the setting precedure as follows.There are at least two ways to do it by either editing the settings from BH menue or using the setting webif (access it by using your webbrowser). The menue settings can be done by following the procedures.
1. Press Menue Button > select plugin > select LCD4linux (this leads to LCD4Linux configureation )
2. Using blue function button (twice) , access to idle setting section ( you can see the setting title from display)
3. Looking for the 'clock section', when you find the 'clock', you may change these perametrs
_Clock type (you can select date+day, time .... just pickup one you like)
_Size (you can using the direction button to increase or reduce the size of the clock's font)
_Position (This parameter moves the display up or down)
_Alignment (This parameter gives the option left, or right, or centre)
Remember to using green button to save the configuration.
I assume you do not remap your remote control's code. Otherwise, the button may be different from the above.
When you manage to change one screen, you can do whatever you like. It is fun! Good Luck!
