Duo2 LCD4Linux lcd display layouts
Ich verstehe nicht,für das Duo2 brauchst du garnicht das Plugin,
schaut mal im VTi Board da gibt es picons für LCD display und soger die transparenten kann mann im Skin nutzen.
Hi all,
First, thanks for all your work! I'm new user of a Duo2 with Vti image. I've managed to use LCD4linux, btu, the VFD is always "blank" when in use...I've tried many things, but still nothing on the screen...
I know it works because when I go in the menu, it works perfectly...
Actually, I'd like to have the colour LCD with : at the top : temperature, RPM and sat info.
Then, centered and quite big : the channel picon.
at the bootom : time.
And in the center LCD : 3 lines :
Name of the program
time of the program (eg : 18h30 - 20h00)
Progress bar.
Hope you can help me...thanks!
hello,
I will try to explain clearly how to update the plug-in
1 - unzip the file (the last release) "enigma2-plugin-extensions-lcd4linux_3.9-r3_mips32el" with 7zip.
2 - we will have a "data" folder (again, we unpack with 7zip)
3 - in "data" are two folders "usr" and "tmp"
4 - with "ftp" it connects and goes to the folder "usr/lib/enigma2/python" from the "vu +"
5 - I replace the contents of each folder by equivalent decompress (not to replace the folder, but the file).
I hope this is clear and that is the right way
hello everybody, is it possible to adjust the screen in the middle the vfd display? in standby my clock is not showing wright its ''sunk down'' in standby and on is not ok either. i think the fonts are to big and not alignd. grtz peter
thanks for your reply eragon.
im trying not to reinstall bh because my cardsharing to bedroom tv finely running smootly.
cant i download the Original skin_user.xml someware for the latest bh?
NO EMU OR ILLEGAL ACTIVITIES HERE PLEASE!
Read Board Rules! 1 week ban.
maybe i have missed something but how do i install new lcd skin and what do get from the new v4.0 skin ? is there something i have missed ?
How to update the letest version from BH 2.0.9? When we update the Ver 3.9-, we have to update by manual install. Can we update from BH server by the addon function in the BH 2.0.9 ?
