TSmedia enigma2 plugin by mfaraj57
please Mr mfaraj57 can you just explain the source of error in alluc ( error ;addon error,no returned data ,ceck details
tsmedia_log
TSxpath:adding TSmedia directories to system path......
TSxpath:Finished adding TSmedia directories to system path......
TSxpath:executing addon default......
sys.argv-xpath ['/usr/lib/enigma2/python/Plugins/Extensions/TSmedia/addons/movies/plugin.video.alluc/default.py', '1', '']
Here in xbmc-py
Here in xbmc-py B
addon path params:plugin_path,addons_path,scripts_path,addon_id /usr/lib/enigma2/python/Plugins/Extensions/TSmedia /usr/lib/enigma2/python/Plugins/Extensions/TSmedia/addons/movies /usr/lib/enigma2/python/Plugins/Extensions/TSmedia/scripts plugin.video.alluc
File "/usr/lib/enigma2/python/Plugins/Extensions/TSmedia/addons/movies/plugin.video.alluc/TSxpath.py", line 36, in <module>
import default
File "/usr/lib/enigma2/python/Plugins/Extensions/TSmedia/addons/movies/plugin.video.alluc/default.py", line 4, in <module>
from metahandler import metahandlers
File "/usr/lib/enigma2/python/Plugins/Extensions/TSmedia/scripts/script.module.metahandler/lib/metahandler/metahandlers.py", line 64, in <module>
ImportError: No module named pysqlite2
Execution finished!!
tsmedia_error
import default
tsmedia_log
Here in xbmc-py
Here in xbmc-py B
import default
tsmedia_error
import default
There is a missing prerequisite: pysqlite2
sorry but the version "TSmedia 7.94" on a VU Duo with image version 2.1.1 (last) works ???
because after you have installed can not find it in the plugin list..
thanks for your help ....
TSmedia 7.95 official release:
- available on 3 diff files basic,full & light
Thanks to mfaraj57.
If you like this, please leave a thank you
@the forum and mfaraj57
Already the day before and now after having upgraded to TSmedia 7.95 I receive an error on my favourite program; Net TV > ExPat TV > categories > British programs (BBC, ITV, etc.).
I then tried to install the previous release, TSmedia 7.94 but the 7.95 remains in position.
How can I force to get the 7.94 installed and how can I solve the errors in the 7.95 release ??
Thanks in advance for your support
From my VU+Solo2
filmon only runs for 5 mins even with user and password entered into tsmedia log in file , under etc/tsmedia/login
is there a solution to this tsmedia 7.9.5 bh image 2.1.2 vusolo
any plugin can work differently depending on the image used . however i use blackhole 2.1.0.1 and i can confirm that there are issues with tsmedia 7.95 . by the way i had to remove the previous version from 3 boxes so far as it crashed the box , the box had to be restarted to view channels , but tsmedia all tho showing in the main menu did not open and if you tried to open it the box crashed .
youtube downloads does not work again , it didnt work on multiple versiions untilll just recently , but then it was fixed but now iagain downloads dont work . can this be fixed please thanks .
i havent tested all plugins in tsmedia , but vdubt25 (in iptv section ) opens and doesnt work , its shows what appears to be raw code . livestream pro and hasbacha does not work . in net media section veetle opens but does not work , docu hub does not work .
in net tv section putlocker tv does not work (but i know there is problems with putlocker) , watchseries does not work , linuxbox streams does not work , ftv does not work .
in movies section icefilms is not there , its replaced with icefilms 2 which works , movie 25 and 1channel work but many other movie plugins do not work , in fact most of them .
also when looking at page one of the movies if you try to look at next page it doesnt work , it only reverts back to page one .
i am not posting this to complain , so please dont think i am complaining , i am just trying to point out some issues with tsmedia using my vu+ solo and blackhole image . i appreciate and i am greatful for all the hard work that goes into tsmedia and i hope my post may help to resolve some of the issues mentioned above .
Icefilms II works fine on the latest version along with Movies25 which is my favourite.Between the two there's enough stuff to keep anyone happy
