TSmedia enigma2 plugin by mfaraj57
Im using the latest Blackhole 3.09 image with Tsmedia, but for some reason it gives me a green screen crash saying "attribute error model object has no attribute parse" tried so hard to fix his but still no luck. Can anyone help me here? ............Thanks
No Answer for U here, please check with the plug-in Author.
TSmedia 15.0
new features:
New style
for first time in enigma added support for watching torrent movies and music
libtorrent c++ needed for this feature to work
libtorrent is device specific and now only available for mispel and arm processors
to check your stb processor type just put in telnet this command
uname -m
if you have other type please feedback to me ,may be possible to prepare one
TSmedia setup will detect your processor type and will install the proper bitorrent library for it
to watch torrent movies just install one of the addons available in the server of TSmedia
TSmedia/movies&series/ add addons
Watching torrent movies is superior to watching through the known movies site because torrent movies have more better qualities and also you can watch 4k movies if available your system available to deal with this resolution
6 popular torrent addons available in the server
EZTV the most popular site for watching tv shows and series
RARBG also popular site for downloading and watching movies
1337x for wathing movies
YTSFY the most popular movies with different quaities
Zoogle torrent movies seearch engine
thepiratebay the most popular torrent search engine
and one more available in arabic secction filmtorrent
subtitles file usually downloaded with the movies and can be found in your download directory
/media/hdd/TSmedia/downloads
to use torrent feature efficiently you need updated image
tested with most of the images successfully including openatve,pure2 and others
torrent not available for dreamos images because the required libraries are not available for this ruppish system
also good internet connection as well as external storage device with good capacity
TSmedia creates movies media library in your storage device and all watched movies kept in this library,libtorrent can resume file with partially downloaded from the point download interrupted
just start and file either complete or partially downloaed and TSmedia will complete download while watching
to check your movies library by blue button downloads,tools like delete and to view other files downloaded with torrent are available
use built in subsupport to download subtitle
to install TSmedia use attachec ipk after moving it to tmp directory and from telnet
opkg install /tmp/enigma2-plugin-extensions-tsmedia_15.0_all.ipk
or without download the ipk
Code
  1. opkg install http://tunisia-dreambox.info/TSmedi...nigma2-plugin-extensions-tsmedia_15.0_all.ipk
or put this script in the tlenet for all systems
wget http://tunisia-dreambox.info/TSmedia/software_official/installer.sh -O - | /bin/sh
for any problem please report here and i am ready to help you
Hi newbie
I just installed TSMedia but cannot set paths to my usb external drive only internal.
Vu Solo, Openpli 7.2.
Any help please THANKS
Have you mounted your usb correct?
Open your mount manager and look if the usb drive is mounted to /media/usb
If the issue is with the plugin then you have to contact the plugin author, and finaly for Pli image they have their own support forum
we here support, Blackhole and OpenBlackhole image and you might consider image change to OpenBlackhole its a very good image and easy to learn :)
HI thanks for your reply. I have an old Vu solo which I mainly use for Viewing films online and sometimes IPTV. I use to have E2istream on it but now its unfortunately dying slowly. What do you suggest I thought I would go for TSMedia but any suggestions are welcome. Also which would go best on my Vu solo Blackhole or Open Blackhole. Remember it's an old chap :-)
HI thanks for your reply. I have an old Vu solo which I mainly use for Viewing films online and sometimes IPTV. I use to have E2istream on it but now its unfortunately dying slowly. What do you suggest I thought I would go for TSMedia but any suggestions are welcome. Also which would go best on my Vu solo Blackhole or Open Blackhole. Remember it's an old chap :)
For your model, I'd choose OBH that's lighter. Or BH installed in Multiboot with OBH in flash.
Surely not BH in flash.
Or, too:
Open BlackHole 4.2 version in flash, and using Open Multiboot with:
1) BlackHole 3.0.9 ( Open Multiboot ), and do an "ONLINE UPDATE".
2) Open BlackHole 4.3.015 ( Open Multiboot ), and do an "ONLINE UPDATE".
Note: When i said 4.2, is really 4.2 ( in Flash ), this not a typo mistake ( because the image is lighter, then 4.3 ), and is only for Multiboot Purposes.
Or, too:
I will surely try and what about plugins what do you suggest instead of E2istream. Thanks again
Hi guys. Sorry to ask someone has brought this up before, but for some reason I can`t delete any files from the Favourites Folder. I press the yellow button but instead of removing files it keeps them in the folder. Any ideas? Thanks. Rhurbarb
I don't remember the meaning of coloured keys under BH within a channel list, but surely, after entering the bouquet, and after having selected the channel, you can press MENU instead. You'll see the options about the channels.
Dixmax for Spanish movies and series
based on android application
plugin Name:international_dixmax_1.0.3
subsection:spain
group:movies
ratings:5
Version:1.0.3
Author:TSmedia Team-Yassinov
Description:videos from Dixmax
