TSmedia enigma2 plugin by mfaraj57
I installed the new 3.0.1C and all it's ok!
Thanks again for the TSmedia 11.0 adult.
Works fine!!!
Only some of the adult videos play on TSmedia 11.0 adult.
Is there any solution to fix this problem?
Thanks mfaraj for your job. Is it possible to have vstream functioning because it's a old version. I need only this addon. Others addon French stream doesn't work. For me, vs is the best. Thanks
Thanks mfaraj for your job. Is it possible to actualice Pelisalacarta 4.05. And, It's possible view a movie torrent from Pelisalacarta?
Hi there. I have got a solo 1st generation. I recently flashed it with black hole image 3.0.1. And installed ts media 11.0. The installation said successfully installed but i cant see the tsmedia in my menu. Can anybody guide me on how to get it to work. I basically wish to watch asian channels through ip, since i dont have a dish setup. Some help would be very nice. Thx guys.
Hi,
It's a bug... You must to flash with the last image (Black Hole 3.0.1C OE3.0).
I have Vu+ solo and I tried install TS media in Universe, but for some reasons I was not able install it in Universe, than TS media was install in flash and not in USB. Is it possible to install TS media in Universe, on USB, or it is impossible?
Thanks
Hi I installed latest update but now vlc tester not showing on iptv section. I installed and restart my box still not showing. I'm using Original VU solo2.please help
