TSmedia enigma2 plugin by mfaraj57
I upgraded version 11.0 and it is awful. lots of time write there is one plugin in Asian tv Zemtv please upgrade this from last 6 upgrades its same and does not work. I know its pointless to write it again and again coz there is hardly anyone to listen and try try to solve this
Hi Alvi1,
I have tried to install Zemtv and it seems as it is not supported in this version. When I have tried to do a 'forced install' it comes up with errors. I can only assume it can not be done because the feed is no longer available. Similar to CartoonHD, they have gone too.
Thanks for your help i know its not work there r 3.9 version of zem tv but in TS they r still using old one and its not working from last 6 or 7 version of TS
Can you please tell me how can i add web channel in vu+ Like http://live.92newshd.tv/ or do you know any addon to watch cricket channel like Geo super, PTV sports, Ten cricket
Thanks
I have just installed zemtv on XBMC and a lot of it works, but I do not know what to look for ! In relation to Geo Super, PTV and Ten Cricket..they are all available on Sports Devil...the live.92newshd works great on the pc, but there is a way of entering that link on Blackhole as a live feed but I have run out of time to try.
thanks what do u mean cannot install it on 3.0.1 . i try 2 install bit its not working in kodi and tsmedia
Sorry
TS media 11 can not be installed on blackhole image 3.0.1. Some file is missing when trying to run it.
The same happens with 10.9 when i tried it
Smedia-27112015-11.0-updates only for TSmedia 11.0
updates & fix applied since v11.0 official release:
fixed overlapping graphics , youtube-fix , ok.ru fixed , add missed international group , subssupport fixed
How to install updates successfully :
- Send updated.ipk to /tmp
- Telnet command > opkg install -force-overwrite /tmp/*.ipk
- Restart E2
thanx @mfaraj57
I have Tsmedia 10.9 installed on blackhole 2.1.7 on a solo2. I can only get youtube.
Many options of movie providers, most of which go through all the categories without probs until I select a movie or tv series episode to view. I get the same message each time " Error:Addon error,no returned data,check details with info button".
The info button gives me pages of script which might as well be klingon. help please, I will be happy to get genesis working.
I have had the same problems for months and have tried on numerous occasions to get solutions on here. I have finally opted for Blackhole 3.0.1 and installed IPTV which has loads of movie and series options. Its working well and havent needed to install TS media again. Its a great plugin when it works but I find it too problematic and I just dont have time to continously try to fix it.
I installed the TSmedia 11.0 adult but my VU solo2 can't restart and stay in the first blue screen with the blackhole logo.
Does anyone knows what happen and how can i fix this problem?
