TSmedia enigma2 plugin by mfaraj57
before you can see the ipk file in the manual install panel you have to put the file into the box using dream control center or vu control center . this is basicly a program that lets your computer connect to your box and then you can use that program to send a file (in this case an tsmedia ipk file) in to your box , this is what is called FTP or to ftp a file to your box . once that file is in then you can access the manual install panel and the file will be displayed there for installation .
did alluc work fine is this version friend can u tested please and tel me if its work ok or not always error data!!
TSmedia 7.96 official release:
- available on 3 diff files basic,full & light
Thanks to mfaraj57.
If you like this, please leave a thank you
Thanks to mfaraj57.
hej 7.96 version teledunet arabic does not Work with ts image .
someone can replay and tel if does Work
thanks
i need to report a problem with tsmedia 7.94 and tsmedia 7.95 using vu+solo and blackhole i2.1.0.1 mage . i know a new version has been released but this problem may also occur on the latest version so its worth mentioning here .
with tsmedia 7.94 after about 1 week when i pressed menu button and selected tsmedia , tsmedia started to load but only for a few seconds and then tsmedia disappeared from the screen . this caused the box to be stuck , the box had to be rebooted , i tried this 3 times and every time tsmedia failed . tsmedia had worked fine up to this point , so the problem just occured and i dont know why .
this problem also occured on two other vu+solo boxes in other houses also using blackhole image , so it is just not my box . some people may not have noticed this problem because a new version of tsmedia that is tsmedia 7.95 was released , so if anyone had 7.94 and quickly upgraded to 7.95 they may not have noticed this problem .
tsmedia 7.95 has the same problem , after allmost 2 weeks of working ok tsmedia 7.95 now has the above problem . if i press menu and select tsmedia it loads a few seconds and then disappears from the screen and the box is stuck . on tsmedia 7.94 and tsmedia 7.95 after this problem starts tsmedia will not work , if you uninstall and reinstall tsmedia it may fix the problem for a few days and then the problem may return .
i know there is now tsmedia 7.96 but i am posting as this problem may also be a problem in the new version of tsmedia ,i hope this post helps to fix the problem . i would like to post my tsmedia error log but i cant find it in my box (maybe because tsmedia does not work ) can anyone tell me the correct location of tsmedia error log so i check ? thank you .
have the same problem
didnt know that its for version 7.94 and 7.95
will try and install 7.93 and check
when i did came back home today i had the same problem that ts media just went away and i could not do anything, needed to restart and did try to open tsmedia again and same thing happen, i will try to re install it, have been working many week with no prob, Strange that this hapend now hmmmm
Thanks to mfaraj57.
Having problems with TSmedia 7.96 full with the IPTVworld. Giving me error massage (Addons error, no returned data, check details with Info button). Any suggestion would be appreciated.
The following is a quote by the author
'yes because the source link changed
i will update the addon as soon as possible
you can use instead /iptv_plugin.video.hasbahcam3u_1.0.1(download from tools/addons/iptv)'
