TSmedia enigma2 plugin by mfaraj57
Hi
How come desifilm or einthusan does not work on blackhole 2.1.2 vu+ uno?
It has not been working for a very long time. Please can anyone advise how to make these work?
Keep getting "error,no returned data, check details with info button"
This error has been the same since previous tsmedia versions
Well I've been using this plugin for about 18 mths now and it's been great but BT have now blocked most of the addons(shame)It was great while it lasted and I've found this liitle unblock for movies25.I tried it yesterday and this morning and it still worked but I don't know for how long.
1) open tsmedia and Movie25 press green button and in the Domain field type
http://movie25.unblocked.pw/
change enableDomainFromFile to false
2)open your FTP Client and go to ect/TSmedia right click on proxy_links and edit the text for Movie25 to this
movie25$movie25.com$http://movie25.unblocked.pw/
restart Tsmedia 7.98 and Movie25 should be working
Thanks....done all that still not working....link error...
you
No....How do I do that please? .:help:
you need to google free proxy servers then set one up ...then search for files proxy.php and htaccess.text and the easy guide to unblock . Cant upload the files here because dont think the forum rules allow. Once set up all the links work
Hi,
have a big problem with Ts media 7.98.
installed on a Vu plus Solo 2 os 2.1.13 fresh installation
when i try to start it, i can see ts media splash screen but after nothing.
it goes back to normal tv.any idea on what could be the problem?
Thanks
And yes, like "cargen" #490, to my surprise I can't start TSmedia. Only get the logo for one second and then it is gone. No movies, no downloads, no tv-programmes.
Please mfaraj57 help to solve these problems for ever, so we can place a Thanks to mfaraj57 again soonest.
same problem ; ts media does not start ...
also uninstalled then re-installed 7.98 & even earlier versions but none of these solved the problem ...
any help appreciated ... thanking you in advance ...
Hi,
Thanks
Same here.....
