TSmedia enigma2 plugin by mfaraj57
Hi, thanks for your work!
I have a solo (1) with BH 2.1.4 and I have tried -tsmedia-oe2-0_7-98_light.
But it's unstable. Witch file must I use?
How to uninstall properly tsmedia?
Many thanks in advance
Try what I installed: TSmedia 2.98 full version on my Vu+solo2.
Good luck !
@petine
I think you meant 7.98, no?
I have tried this latest ipk. Unfortunately every time i try to open UK tvs I get green screen. I have not tried anything else as i had no time last night due to footy. I have it on vu solo latest BH 2.1.4
@petine
You are wright, it is 7.98.
In TSmedia go to Net TV and then select FilmOn and select UK-Live-TV. On top check also your Add-ons.
Good luck.
I understand that ice films has been blocked in UK & maybe Mikeys Karaoke. Error code is failed to extract control file from/tmp/okpg-Alxws5/movies_plugin.video.icefilms_0.0.6.zip.
Will setting up a proxy solve this issue?
TSmedia 7.99:
- new addons & bug fixes
- available on 3 diff files basic,full & light*
Thanks to mfaraj57.
If you like this, please leave a thank you
TSmedia 7.99:
Thanks to mfaraj57.
Thank you mfaraj57 & ennegi ...
Youtube download no longer working for me ... anyone else has same problem?
Hi, thank you so much for the latest update - testing it now.
Is there any way of getting "Youtube on Fire" and "Simplymovies" back...?
Thanks again for the great work.
TSmedia 7.99:
Thanks to mfaraj57.
Hi, @ennegi, Would you please confirm the version of last file which you uploaded? they are labeled as basic, all and full-all, but the last one with a version number as 2.0_7.9 rather than a 2.0_7.99. Is it just a typing error?
TSmedia 7.99 (update):
Thanks to mfaraj57.
(@mysat-bs: here are the two files right)
Thanks to mfaraj57.
I get green screen and enigma restart every time I go in any category (eg iptv)
bh 2.1.4 (clean)
bh 2.1.4 (clean)
You can update with TSmedia himself, it's THE best solution...
Downgrade TSmedia from 7.5 (or just stable before upgrade and GS) and update with the panel integrated software, you'll have a clean installation...
sometimes the reason it doesn't work is your ISP is blocking a site - a friend brought his receiver over to me and it worked but took it home and it didn't work
plusnet are better than BT as a provider it seems
