Usb Tuner IT9135 Alfatech
demetris
Hello,
Is it possible to add support for this chip?
http://www.linuxtv.org/wiki/index.php/Kworld_UB499-2T
http://wasietsmet.nl/hardware/zolid-usb-dvb-t-tuner-van-de-aldi-linux-drivers/
http://hosting.pilsfree.cz/qwerty/driver/9130.linux.PC.dvb-tV9.12.18.1/
Thanks
Not working,
No usb tuner found.
Thanks for the support
I already suspected this kind of tuner doesent work correctly :(
I've developer on dark :(
Please make this try:
1. reboot box and post here the "dmesg" command
2. post the output of cat /proc/bus/usb/devices
Thanks for your patience!
root@bm750:~# cat /proc/bus/usb/devices
T: Bus=04 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=12 MxCh= 2
B: Alloc= 0/900 us ( 0%), #Int= 0, #Iso= 0
D: Ver= 1.10 Cls=09(hub ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=0000 ProdID=0000 Rev= 2.06
S: Manufacturer=Linux 2.6.18-7.3 ohci_hcd
S: Product=BRCM OHCI
S: SerialNumber=ohci-brcm
C:* #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr= 0mA
I: If#= 0 Alt= 0 #EPs= 1 Cls=09(hub ) Sub=00 Prot=00 Driver=hub
E: Ad=81(I) Atr=03(Int.) MxPS= 2 Ivl=255ms
T: Bus=03 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=12 MxCh= 2
T: Bus=02 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=480 MxCh= 2
B: Alloc= 0/800 us ( 0%), #Int= 0, #Iso= 0
D: Ver= 2.00 Cls=09(hub ) Sub=00 Prot=01 MxPS=64 #Cfgs= 1
S: Manufacturer=Linux 2.6.18-7.3 ehci_hcd
S: Product=BRCM EHCI
S: SerialNumber=ehci-brcm
E: Ad=81(I) Atr=03(Int.) MxPS= 2 Ivl=256ms
T: Bus=01 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=480 MxCh= 2
B: Alloc= 0/800 us ( 0%), #Int= 1, #Iso= 0
T: Bus=01 Lev=01 Prnt=01 Port=01 Cnt=01 Dev#= 2 Spd=480 MxCh= 0
D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=048d ProdID=9006 Rev= 2.00
S: Manufacturer=ITE Technologies, Inc.
S: Product=DVB-T TV Stick
C:* #Ifs= 2 Cfg#= 1 Atr=80 MxPwr=500mA
I: If#= 0 Alt= 0 #EPs= 4 Cls=ff(vend.) Sub=00 Prot=00 Driver=(none)
E: Ad=81(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=02(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=84(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=85(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I: If#= 1 Alt= 0 #EPs= 1 Cls=03(HID ) Sub=00 Prot=01 Driver=usbhid
E: Ad=83(I) Atr=03(Int.) MxPS= 64 Ivl=64ms
Ok.
You have tried to enable the tuner into USB Tuner Panel? I think YES but I need confirmation from you.
I will update the drivers for your stick no the server within 30 mins approx.
Hi,
Driver seems to work but no channels found.
When you scan for channels you have an instant 0% to 100% 0 channels found
I: If#= 0 Alt= 0 #EPs= 4 Cls=ff(vend.) Sub=00 Prot=00 Driver=dvb_usb_it9135
Also what to choose from this, "sorry first time on dvb-t usb" :)
I cant find Cyprus-Europe
I have options Iceland dvb-t europe-middle east dvb-t australia dvb-t etc
And
What Mhz to put the tuner i have options from 6-8MHZ
root@bm750:~# cat /proc/bus/nim_sockets
NIM Socket 0:
Type: DVB-S2
Name: BCM7335 DVB-S2 NIM (internal)
Frontend_Device: 0
NIM Socket 1:
Type: DVB-S2
Frontend_Device: 1
NIM Socket 2:
Type: DVB-T
Name: DVB-T TV Stick
Frontend_Device: 2
root@bm750:~# ls -l /lib/firmware
-rw-r--r-- 1 1000 messageb 238 May 28 18:47 af35irtbl.bin
-rw-r--r-- 1 1000 messageb 25105 Oct 13 23:18 dvb-usb-it9135.fw
-rw-r--r-- 1 root root 2048 Oct 12 11:54 rt73.bin
Your dmesg and output about /proc/bus/usb/devices is very good. Device correctly detected.
I will study the other errors reported on your last dmesg.
Thanks awaiting for your instructions. Thanks again
P.s
Does it help if i reboot the box and post a fresh dmesg?
It's not necessary. All the useful infos are being psoted into your last dmesg who shows correct detect and startup of your device.
I will work to solve the "0 service found" ....
Thanks for your time man, really appreciated.
i hope to finally be able to watch digital tv on my Vuduo, i thought i would never be able but thanks to you my hopes have reborn!
