Usb Tuner IT9135 Alfatech
root@bm750:~# lsmod|more
Tainted: P
dvb_usb_it9135 71632 2 - Live 0xc04d5000
dvb_usb 23952 1 dvb_usb_it9135, Live 0xc04b9000
ntfs 309536 0 - Live 0xc05c3000
vfat 11776 0 - Live 0xc04c5000
fat 57520 1 vfat, Live 0xc04e9000
sr_mod 16128 0 - Live 0xc04c0000
cdrom 43296 1 sr_mod, Live 0xc04c9000
usb_storage 40720 0 - Live 0xc049c000
cifs 281808 0 - Live 0xc0518000
isofs 25744 0 - Live 0xc04b1000
brcmfb 3216 2 - Live 0xc00df000
fb 31072 5 brcmfb, Live 0xc04a8000
dvb_bcm7335 4928816 36 brcmfb, Live 0xc06af000
dvb_core 105520 2 dvb_usb,dvb_bcm7335, Live 0xc014f000
procmk 2112 1 dvb_bcm7335, Live 0xc00e1000
snd_pcm 73504 1 dvb_bcm7335, Live 0xc0118000
snd_timer 24016 1 snd_pcm, Live 0xc0092000
snd_page_alloc 8592 1 snd_pcm, Live 0xc00db000
snd 53552 3 dvb_bcm7335,snd_pcm,snd_timer, Live 0xc00ef000
soundcore 9552 1 snd, Live 0xc00a0000
firmware_class 10688 1 dvb_usb, Live 0xc0082000
i2c_core 19936 2 dvb_usb_it9135,dvb_usb, Live 0xc009a000
nls_iso8859_1 3840 0 - Live 0xc0090000
nls_cp437 5504 0 - Live 0xc008d000
nls_base 7504 6 ntfs,vfat,fat,cifs,nls_iso8859_1,nls_cp437, Live 0xc0086000
evdev 9664 2 - Live 0xc0089000
usbhid 66640 0 - Live 0xc00c9000
input 24944 8 dvb_usb,dvb_bcm7335,evdev,usbhid, Live 0xc0074000
sata_svw 18000 1 - Live 0xc007c000
libata 144352 1 sata_svw, Live 0xc00a4000
Replaced and Works.
But Same issue as before 0 channels.
Maybe is trying to scan from the hid keyboard driver that the dvb-t has?
Hi,
If problem found do i need to reflash box with newer image e.g. 1.6.7?
Or it will be solved to function on current one.
Thank you in advance.
After install of 1.6.6 BH version i download the driver from panel, reboot, and search DTT channel.
It found 54 channel.
It work for me.
but 54 channel is very low.
1) do you know if is it necessary manual searching ?
2) in the tuner setting there is : "5V to antenna" must be enabled or not ?
It work for me.
VERY INTERESTING!
Could you please put here the output of "dmesg" command when the box complete bootup? It's very important for me to diagnose and see the correct detection of this kind of devices.
1) I'm the first that have this working ?
2) give me instruction for dmesg, i do not know very well linux
3) please respond to other my question also (se non altro per educazione)
ciao
ciao
You are right. You are the first people who use with success an IT9135 device and I'm very curious about it's detection.
I use always "Manual Search" -> select DVB-T tuner -> Scan complete. I haven't done an "Automatic Scan" in my linux-box life.
For isntruction about "dmesg" command this is the procedure:
0) get Putty from the Web or this Board (Tools and Settings section)
1) your box must be connected to a network (LAN or Wireless)
2) login into your box (open Putty, put the IP address of your box into, select TELNET from Protocols) and press Open or Connect
3) when the box ask for user/password, put your credentials.
4) when the prompt appear give this command "dmesg > /tmp/dmesg.txt" and press Enter
5) now you can open Filezilla FTP client, connect to your box, browse the /tmp folder and retreive the dmesg.txt file. That file will be uploaded here.
6) you can close putty and filezilla client.
Thank you for your patience and support
If I've missed an answer please remember me :(
Please testato help us to identify whats wrong with our DVB-T's.
Waiting for your report, thanks in advance.
Angelofsky1980: Do you think is working because of Solo platform?
my forgotten qustion is :
for manual search i mean manually chose the frequency, example 490000 for RAI
now i create dmesg and attach it
thanks to you for your work
