Usb Tuner IT9135 Alfatech
I should have figure out the problem:
I got this device, and it doesn't have any manufacturer/product name stored on its internal memory. the usbtuner helper should return "unknown frontend" but there is a bug.
Tomorrow I will try to fix it! It shouldn't be so difficult...
Latest Black Hole (BH) image is 3.0.3.H includes a good driver for IT9135. I have Ultimo and it works fine. The driver is built into the BH and there is no need to manually install it. Please check your BH version and if older firmware update firmware of receiver.
Hello. I was wondering if you can attach the final driver of this chipset so I can install it mannually to my sisters reciever because she dont have internet connection on her house. She using common interface and she want to watch channels via dvb-t usb stick via the reciever. Many thanks.
i have 2 turner , one in solo2 con bh 3.0.7 perfect funtion, other zero perfect con 3.0.7, con 3.0.8 no funtion.
with other bh 2.xx 3.xx in time no funtion pixelation stream, repeat bh 3.07 perfect
you mean not detected? need dmesg output (I hope to see some error)
However I've tested that pen on 3.0.8 on uno4k and it is detected and channel scan works (as quick regression test)
